[fusion-users] RE: [fusion-dev] fusion 1.1 planning
Chris Claydon
chris.claydon at autodesk.com
Wed May 7 14:39:08 EDT 2008
MG releases prior to 2.0 should ignore the FORMAT parameter used to request a JSON response, and simply return XML. So if Fusion checks the mime type of the response, it should be able to determine whether or not it needs to call the internal xml2json stuff.
When the MG JSON support was implemented, every effort was made to ensure that the JSON produced would be the same as that created by Fusion's internal converter, so the transition should be relatively straightforward :)
Chris.
-----Original Message-----
From: fusion-dev-bounces at lists.osgeo.org [mailto:fusion-dev-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: May 7, 2008 12:17 PM
To: Paul Spencer (External); fusion-dev at lists.osgeo.org
Cc: fusion-users
Subject: RE: [fusion-dev] fusion 1.1 planning
Is Fusion using the MapGuide MapAgent JSON output implemented in:
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc25
yet? I've managed to get a bit lost trying to figure out what is going
on, but as far as I can tell it's doing requests without specifying
content type, and post-processing the XML into JSON. I'd imagine that
this would have substantial performance benefits.
If the json format output by MapGuide is the same as that used by the
internal xml2json stuff, this probably wouldn't be a huge change. But
it may need to be configurable if supporting < 2.0 MapGuide releases is
important?
Jason
Subject: [fusion-dev] fusion 1.1 planning
We'd like to start planning for a fusion 1.1 release this summer
sometime. I don't have a specific feature set or time frame in mind
for a release, but it would be nice to have it before FOSS4G (Sept
2008).
My primary goals for a 1.1 release are:
1) improve performance (and reduce library size),
2) take advantage of more OpenLayers features,
3) API cleanup and documentation
Currently, Mike is working on the following aspects (some are already
complete):
* upgrade to OpenLayers 2.6 final
* move from Prototype.js framework to OpenLayers equivalents (freeing
us up to move away from Prototype.js and Scriptaculous in the Jx
library)
* make more extensive use of OpenLayers handlers/controls in place of
existing widget code that does the same thing
* implement support for other OpenLayers layer types through the
MapGroup tag in the ApplicationDefinition
* improved single file builds (including a 'compiled application'
capability)
I will be working on a new version of Jx that will use MooTools
instead of Prototype.js and Scriptaculous which will give Jx a smaller
final size and more cinematic effects. I will be updating Fusion to
use the new Jx for 1.1 as well.
The net effect of all these changes will be to reduce the size of the
code base (streamlining initial start up) and remove extraneous code
(probably not a noticeable runtime effect yet).
There will also be some bug fixes of course, but I don't see any
substantial work going into new widgets unless there are some new
contributors willing to get involved.
fusion-dev mailing list
http://lists.osgeo.org/mailman/listinfo/fusion-dev
More information about the fusion-users
