[fusion-users] Fusion release 1.0.5
Zac Spitzer
zac.spitzer at gmail.com
Thu May 8 22:23:26 EDT 2008
ok, i did that. I renamed the folder, installed 1.0.5 and then copied
across the mg templates
from the old fusion/templates/mapguide directory
It works ok, but the status bar elements are all on top of each other
with the slate template
also, my mgserver had crashed (again) and fusion just sits there doing
nothing without any
feedback that there was no response from mapguide
http://trac.osgeo.org/fusion/ticket/2 is still not working, i getting
88 44 instead of 87 43
z
On Fri, May 9, 2008 at 11:43 AM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> Rename it / back it up.
> You'll need to copy the MapGuide templates from the distributed fusion folder into the new fusion folder after installing. I haven't had a chance to test this release yet :(
> Jason
> ________________________________
> From: Zac Spitzer
> Subject: Re: [fusion-users] Fusion release 1.0.5
> To install on an existing mapgudie instance, do we overwrite the
> fusion folder or should i delete it first?
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
More information about the fusion-users
