[fusion-users] Fusion release 1.0.5
Mike Adair
madair at dmsolutions.ca
Fri May 9 11:03:29 EDT 2008
Zac,
Thanks for testing. Perhaps we should put in place some sort of RC
process to shake out bugs like this.
I've got a fix for the StatusBar problem in Fusion, but getting that out
there would require another release. I'm not sure why that doesn't
occur with the standard template, but the solution is to force a resize
on Container elements once they get created.
For issue #2, with the slate template I'm seeing 87.7045, 43.7656 at the
intersection of Park Ave and N 3rd St. which I think is the correct
coordinates. Are you only getting 2 digits of precision? Make sure
that the CursorPosition widget has <Precision>4</Precision> in it's
<Extension> element. If that's not the case can you point me to a URL
that shows the incorrect locations?
For the MgServer crashing issue, that wasn't addressed in the release,
but it would be good to do something about that in a future release.
Can you enter a trac ticket for it please?
Thanks again for the reports.
Mike
Zac Spitzer wrote:
> ok, i did that. I renamed the folder, installed 1.0.5 and then copied
> across the mg templates
> from the old fusion/templates/mapguide directory
> It works ok, but the status bar elements are all on top of each other
> also, my mgserver had crashed (again) and fusion just sits there doing
> nothing without any
> feedback that there was no response from mapguide
> http://trac.osgeo.org/fusion/ticket/2 is still not working, i getting
> 88 44 instead of 87 43
> z
> On Fri, May 9, 2008 at 11:43 AM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
>> Rename it / back it up.
>> You'll need to copy the MapGuide templates from the distributed fusion folder into the new fusion folder after installing. I haven't had a chance to test this release yet :(
>> Jason
>> ________________________________
>> From: Zac Spitzer
>> Subject: Re: [fusion-users] Fusion release 1.0.5
>> To install on an existing mapgudie instance, do we overwrite the
>> fusion folder or should i delete it first?
More information about the fusion-users
