[fusion-users] Widget Functions.
Tómas Guðmundsson
tomas at snertill.is
Wed May 14 10:11:36 EDT 2008
I tried what you guys said. Here is the block I added. Note my widget is called sneBlockUI.
ApplicationDefinition.xml:
* Trying to load extra javascripts
* with xml here. Required by fusion.
<Container xsi:type="UiItemContainerType">
<Name>sneBlockUI</Name>
<Type>Block UI</Type>
<Item xsi:type="WidgetItemType">
<Function>Widget</Function>
<Widget>sneBlockUI</Widget>
</Item>
</Container>
index.html:
<div id="sneBlockUI"></div>
Do I need to add the widget (xml) definition for sneBlockUI as well ?
-----Original Message-----
From: fusion-users-bounces at lists.osgeo.org [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Mike Adair
Sent: 14. maí 2008 13:52
To: Alan Boudreault
Cc: fusion-users at lists.osgeo.org
Subject: Re: [fusion-users] Widget Functions.
Also, widgets must be associated with a DOM element to be instantiated.
This can be either through a <Container><Item> element, or simply
through a <div id='widgetName'> element in the page (I think this
works). You can try putting a breakpoint in the widget constructor to
see if it ever gets instantiated.
Mike
Alan Boudreault wrote:
> Where is defined you class sneBlockUI ? Can you check with firebug if
> the file you defined this class is well loaded ? Fusion does'nt load
> all the "TheWidget.js" files by default, only those that are
> required. (Those defined in the ApplicationDefinition.xml)
> Regards,
> Alan
> Tómas Guðmundsson wrote:
>> Yeah,
>> Here are the errors I get via firebug.
>> Fusion.Widget.sneBlockUI is not a constructor
>> - this.blocker = new Fusion.Widget.sneBlockUI(); ---
>> sneRefreshMap.js (line 8)
>> blockUI is not defined
>> - blockUI(); --- sneRefreshMap.js (line 16)
>> What I am aiming for is this blocking of the ui while the map is
>> rendering so maybe I should just modify the Map.js ?
>> However here is the code.
>> Fusion.Widget.sneRefreshMap = Class.create();
>> Fusion.Widget.sneRefreshMap.prototype = {
>> initialize : function(widgetTag) {
>> //console.log('RefreshMap.initialize');
>> Object.inheritFrom(this, Fusion.Widget.prototype, [widgetTag,
>> true]);
>> Object.inheritFrom(this, Fusion.Tool.ButtonBase.prototype, []);
>> this.dialog = null;
>> * execute function.
>> execute : function() {
>> var map = this.getMap();
>> blockUI();
>> map.redraw(); },
>> blockUI : function() {
>> if (!this.dialog) {
>> var size = Element.getPageDimensions();
>> var o = {
>> title: OpenLayers.String.translate('Loading'),
>> imageBaseUrl: this.imageBaseUrl,
>> width: 150,
>> height: 85,
>> resizeable: false,
>> top: (size.height-200)/2,
>> left: (size.width-320)/2,
>> this.dialog = new Jx.Dialog(o);
>> this.dialog.open(); }
>> From: Paul Spencer [mailto:pspencer at dmsolutions.ca] Sent: 14. maí
>> 2008 11:25
>> To: Tómas Guðmundsson
>> I'm not sure about the first error, can you send code for us to look at?
>> For the second, try:
>> var myObject = new Fusion.Widget.MyNewWidget();
>> Paul
>> On 14-May-08, at 5:57 AM, Tómas Guðmundsson wrote:
>>> Hi all.
>>> I have been wondering about a very strange "bug" but then again
>>> this might be something that you don't notice until you've told
>>> everybody about it and feel like a complete idiot.
>>> I'm trying to create a code that extends the refresh widget by
>>> opening up a ui-blocking page like the Print widget does. However,
>>> if I just use the pure code from Print.js, like copy/paste. Firebug
>>> gives me an error that the function can not be found. Totally
>>> cryptic to me. It is defined exactly like the Print.js widget, do I
>>> need to define my functions somewhere else ?
>>> Also, if I have created a seperate widget that I want to use just
>>> like a new class in a conventional programming, like so.
>>> var myObject = new MyNewWidget();
>>> Do I need to call Fusion.Class or something ?
>>> Thanks
>>> Tomas
>>> fusion-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>> Paul Spencer
>> Chief Technology Officer
>> DM Solutions Group Inc
>> http://www.dmsolutions.ca/
More information about the fusion-users
