[fusion-users] Mapguide Eventhandling with Fusion.
Paul Spencer pspencer at dmsolutions.ca
Thu May 15 07:11:46 EDT 2008
Are you using Firefox and the (awesome) firebug extension?  If yes,
then you can get a stack trace at that point.  I'm not sure what is
going on, that event is defined and registered in Map.js so if you can
call this.getMap().registerForEvent then the map widget has been
initialized and that event should be available.
Can you send code (directly to myself if necessary) for your widgets
so I can take a closer look?
Paul
On 15-May-08, at 5:37 AM, Tómas Guðmundsson wrote:
> Paul,
> I tried this and it works but it gives me an error.
> Inside the function triggerEvent on line 1041 inside
> fusion.js it gives me an error with a popup alert :
> Fusion Error:
> WARNING: Exception occurred in AJAX callback.
> TypeError: this.events[eventID][i] has no properties
> Location: undefined (1041)
> xx)
> Where undefined is actually fusion.js and line 1041.
> Here is the function I have running in a javascript
> widget that is being executed.
> this.getMap().registerForEvent(Fusion.Event.MAP_BUSY_CHANGED,
> alert('MAP_BUSY_CHANGED'));
> Regards,
> Tómas.
> -----Original Message-----
> From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
> Sent: 14. maí 2008 17:39
> To: Tómas Guðmundsson
> Cc: fusion-users at lists.osgeo.org
> Subject: Re: [fusion-users] Mapguide Eventhandling with Fusion.
> Tómas,
> these are not the droids you are looking for!  These events only
> relate to loading the map definition from the server, not drawing the
> map.  You want Fusion.Event.MAP_BUSY_CHANGED.  This gets called when
> the map starts drawing and again when it is finished, but you need to
> check map.isBusy to see if the map is still busy or not because
> several busy states can be queued up.
> Cheers
> Paul
> On 14-May-08, at 12:57 PM, Tómas Guðmundsson wrote:
>> Hi all.
>> I just conducted a little experiment with the Event Handlers in
>> Map.js
>>       map.registerForEvent(Fusion.Event.MAP_LOADING,
>> alert('MAP_LOADING'));
>> map.registerForEvent(Fusion.Event.MAP_LOADED,alert('MAP_LOADED'));
>> map
>> .registerForEvent(Fusion.Event.MAP_RELOADED,alert('MAP_RELOADED'));
>> And what I originally thought what would happen that it would give
>> me an alert
>> at first when it was loading, and then when it would load. Then I
>> thought it would
>> give me the third alert when i pressed the refresh map button. But,
>> what happened
>> was before the map was ready or visible to me, they all loaded
>> consecutively so
>> I got three alerts in a row.
>> If anyone can tell me why this is or what the reasons are behind
>> that I would really
>> appreciate that. Also if anyone can tell me how to find out when the
>> map is visible,
>> after a refresh or after any (first or last time a user) sees the
>> gray background of
>> the map itself.
>> Regards,
>> Tómas.
>> fusion-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>    Paul Spencer
>    Chief Technology Officer
>    DM Solutions Group Inc
>    http://www.dmsolutions.ca/
    Paul Spencer
More information about the fusion-users mailing list
