[fusion-users] Multiple Maps and OverviewMap.
Paul Spencer pspencer at dmsolutions.ca
Fri May 16 09:29:48 EDT 2008
Mike,
how is the MapMenu widget set up to allow the user to change maps?
Paul
On 16-May-08, at 9:21 AM, Mike Adair wrote:
> Tomas,
> I've never tried putting 2 MapWidgets in one template before so
> there will likely be some issues around that, but Fusion is
> currently set up to have 1 MapWidget per WidgetSet.  So if you still
> want to try this, put the second MapWidget inside a second WidgetSet
> element in AppDef.
> Putting more than one MapGroup element inside the MapSet has been
> tested and should work OK.  The Map to be shown by a MapWidget is
> selected by the ID attribute.
> Putting more than one Map inside a MapGroup isn't supported yet, but
> it is being worked on and planned for the 1.1 release.
> As for your OverviewMap questions, the MinRatio and MaxRatio options
> should be getting passed in to the control correctly (please file a
> ticket if they are not) but to be honest, I have a hard time
> figuring out how the OpenLayers control behaves too.  It may help to
> define a separate MapGroup for the overview (provide a <MapId> in
> it's extension) so that you can specify different minScale and
> maxScale values that are more appropriate for an overview map,
> rather than using a copy of the main map layer.
> Hope that helps,
> Mike
> Tómas Guðmundsson wrote:
>> Hi all.
>> Happy Friday. Hope you have a wonderful weekend everyone. I have a
>> couple questions for you all.
>> First of regarding the maps. I thought originally that it would be
>> enough to add these two things to the ApplicationDefinition.xml and
>> life would be beautiful but I guess I'm not that lucky.
>> 1. <MapWidget xsi:type="WidgetType">
>> <Name>Map</Name>
>> <Type>Map</Type>
>> <StatusText>The map.</StatusText>
>> <MapId>sheboygan</MapId>
>> <Extension xsi:type="CustomContentType">
>> <MenuContainer>ContextMenu</MenuContainer>
>> </Extension>
>> </MapWidget>
>> 2.
>> <MapGroup id="sheboygan" xsi:type="MapType">
>> <Map xsi:type="MapGuideLayerType">
>> <Type>MapGuide</Type>
>> <SingleTile>true</SingleTile>
>> <Extension>
>> <ResourceId>Library://Samples/Sheboygan/Maps/
>> Sheboygan.MapDefinition</ResourceId>
>> </Extension>
>> </Map>
>> </MapGroup>
>> And with those two added to my AppDef I was hoping to have my main
>> map and then the sample map as well so I could chose between in the
>> <Widget>MapMenu</Widget> but nothing happens. I also get some
>> errors that I think that are encountered with reading between the
>> maps. Just to clear things, I added the MapGroup within the MapSet
>> in the AppDef so I would have two MapGroups and two MapWidgets but
>> I also tried to have two Maps within one MapGroup. Nothing worked.
>> My second question is regarding the OverviewMap. I played a little
>> with the OverviewMap.js and the OverviewMap.xml to see if it would
>> make any changes and nothing happen. Essentially I tried to change
>> some variables like the min and max ratio, oLayerOL.ratio and
>> numZoomLevels but what I'm trying to change in my overviewmap is
>> when you zoom in, in the big map that the overview map doesn't
>> change as well. So after I zoom in 3 times, the overview map starts
>> to zoom in as well and at that time the red binding box in the
>> overview map is so big that it's not feasible to pan around in the
>> overview map. So how can I change the overview map so it that the
>> overview map would never, or after 10 times zoom in. Note: Changing
>> these lines (the value assigned) did not help.
>>        if (this.mapObject.oLayerOL.singleTile) {
>>          this.oMapOptions.numZoomLevels = 3;  //TODO: make this
>> configurable?
>> Also everyone. Have a great weekend. You know it's going to be fun!
>> Regards,
>> Tómas.
>> fusion-users mailing list
>> fusion-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://www.dmsolutions.ca/
More information about the fusion-users mailing list
