[fusion-users] Fusion not finding MapServer
Denise MacLeod Denise.MacLeod at ingres.com
Tue May 20 17:04:31 EDT 2008
Hi all -
I'm new to Fusion and MapServer.
I have followed the tutorial located on the website, http://trac.osgeo.org/fusion/wiki/MapServerTutorial and read thru various parts of the mailing list archive.
I can see the map rendering on a webpage when it's just via mapserver (calling http://localhost/cgi-bin/mapserv?mode=map&map=/home/denise/GeoSpatial/gmap-ms46/htdocs/gmap75.map).
When I load the fusion web page, I created from the tutorial, http://localhost/demo all I see is a simple 2 column table, without any data or labels.
The index.html file  ---> I used the default from the webpage.
The ApplicationDefinition.xml file ---> I used the default from the webpage, ensuring that mapserv executable was in the cgi-bin/mapserv path specified (it already was) and changing the MapFile line to point to my map file (same map file used above).
However, when I attempt to use the fusion interface to view the map, I do not see any data.  Both the php.ini and fusion config file point to /tmp directory; and there are no errors logged in httpd/error_log.
Another interesting point, I took executable perms off of mapserv (on purpose), and I did not receive any errors when loading the fusion webpage. I did receive the correct error when attempting to reload the mapserv page directly (error_log:  [Tue May 20 16:01:35 2008] [error] [client 127.0.0.1] (13)Permission denied: exec of '/var/www/cgi-bin/mapserv' failed)
Any ideas on why fusion is not calling the mapserver executable?  Any more debugging I can turn on?
Thanks,
Denise
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20080520/347f672c/attachment.html
More information about the fusion-users mailing list
