[fusion-users] OL layer in Fusion
Paul Spencer pspencer at dmsolutions.ca
Thu May 22 09:31:17 EDT 2008
yes :)
On 22-May-08, at 9:04 AM, Fusion Newbye wrote:
> How can i add an openlayers Layer into a fusion apllication?
> something like that in applicationdefinition.Xml?
> <MapGroup id="ol" xsi:type="MapType">
> - <Map xsi:type="MapLayerType">
>   <Type>MapServer</Type>
>   <SingleTile>true</SingleTile>
> - <Extension>
>   <MapFile>/ms4w/apps/ol/htdocs/ol.map</MapFile>
>   </Extension>
>   </Map>
> 2008/5/21 Paul Spencer <pspencer at dmsolutions.ca>:
> Theoretically its possible but it is not directly available at this
> time.  If you are handy with firebug, you can poke around inside
> Fusion at runtime to see how to get a hold of the openlayers Map
> instance and directly do anything OpenLayers-y with it.  The ability
> to work more directly with OpenLayers, and to include other Layer
> types through the ApplicationDefinition will likely be in the next
> release.
> Cheers
> Paul
> On 21-May-08, at 2:15 PM, Fusion Newbye wrote:
> I've read that fusion use also code of openlayer so is it possible
> to use google maps and api keys  in Fusion apps?
> Thanks in advance
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
> __________________________________________
>   Paul Spencer
>   Chief Technology Officer
>   DM Solutions Group Inc
>   http://www.dmsolutions.ca/
    Paul Spencer
More information about the fusion-users mailing list
