[fusion-users] Tiling and <SingleTile>
Paul Deschamps pdeschamps at dmsolutions.ca
Fri Nov 7 10:01:17 EST 2008
Hi andrew.
This message you are seeing in the status bar is related to a 500 error that
is occurring in a legend graphic request
http://pitrule.source3.com/fusion//MapServer/php/LegendIcon.php?mapname=Pit%20Rule%20Web%20GIS%20v.08.10&session=491457263740b&layername=Highways&classindex=0
Check your apache logs and it may give you more information as to what error
legendIcon.php is throwing.
If you do not have firebug I would suggest you install it. you can see this
error in the NET tab of firebug.
Cheers
Paul D.
On Thu, Nov 6, 2008 at 9:44 PM, Andrew Parker <andrew at source3.com> wrote:
> Paul:
> I tried a few days ago setting <SingleTile> true/false </SingleTile> in the
> ApplicationDefinition.xml to "true" then to "false".  Currently, I have it
> set to "false".
> If you visit "http://pitrule.source3.com" you will notice that in the
> status bar of FireFox it states "Transferring data from
> pitrule.source3.com", which does not go away.  If I set <SingleTile> to
> "true" the Firefox status bar states "Done" but the Firefox loading icon
> (upper right) continues to turn.  Do I:
> 1. have a memory leak?
> 2. need to ask HostGIS to check if the server is getting hit hard while the
> map is open?
> 3. not worry about it, it is just a bug?
> Thanks.
> ~Andrew
> Paul Spencer wrote:
>> Hi Andrew,
>> you might be able to get it to tile your requests by adding
>> <singleTile>false</singleTile> to the <Map> or <Map><Extension> tag in your
>> application definition, but that won't cache the tiles so it will be hard on
>> the server.  Then again, I haven't really tried doing this so the MapServer
>> stuff in Fusion may ignore singleTile.
>> We are adding support for all OpenLayers layer types soon and then you can
>> specify a WMS layer or TMS layer and point it to a TileCache instance that
>> uses MapServer to generate the map tiles.  It should be in SVN in a week or
>> two and be officially supported in the 2.0 release that should be out before
>> the end of the year.
>> Cheers
>> Paul
>> On 6-Nov-08, at 9:34 AM, Andrew Parker wrote:
>>  Stuart:
>>> I do not have an answer for you.  But I am starting work on a similar
>>> problem today and would like to have a solution by next Wednesday.  Below is
>>> a brief description of what I am trying to do.  FYI: I am not a developer so
>>> I have no idea how to go about doing this; but I have a programmer to turn
>>> to for help.
>>> I am running Fusion for MapServer.  I have not installed Mapguide OS.  I
>>> want to enable tiling for this site:  http://pitrule.source3.com.  And
>>> change my "Base Map" group in the Legend from checkboxes (overlay) to radio
>>> buttons (basemap).
>>> All the threads I have seen talks about using MapGuide, but I have not
>>> found any howto's or suggestions to implement tiling for Fusion for
>>> MapServer.  I am clearly not understanding something.
>>> Lastly, when I figure out how to do this, I will be creating a howto.  In
>>> addition, I will create a new topic for my progress as I do not want to
>>> impose on your thread.
>>> Good luck and if I see a solution for your issue I will let you know.
>>> ~  Andrew
>>> gingerbbm wrote:
>>>> Right, well I found this thread:
>>>> http://n2.nabble.com/Fusion---Base-layers-questions...-td1303997.html
>>>> So again I need to find a workaround...
>>>>  _______________________________________________
>>> fusion-users mailing list
>>> fusion-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>>   Paul Spencer
>>   Chief Technology Officer
>>   DM Solutions Group Inc
>>   http://research.dmsolutions.ca/
   Paul Deschamps
   Applications Specialist
   DM Solutions Group Inc.
   Office: (613) 565-5056 x28
   http://www.dmsolutions.ca
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20081107/775a9599/attachment.html
More information about the fusion-users mailing list
