[fusion-users] Accessing the Task Frame / Selection changed
Rodolfo Moreno rmoreno at voxiva.com
Sun Oct 12 10:48:19 EDT 2008
Hi Paul,
It works good.
the url obviously could has parameters using the GET method, however I would
like to send the parameters with the POST method mainly for sending the
selected features to my ASPX page due to that the number of selected
features and their properties could exceed the allowable length of the
querystring of the GET method.
Berdel, Brian wrote:
> Great, thanks Paul.   I'll give it a try.
> Brian
> -----Original Message-----
> From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
> Sent: Wednesday, October 08, 2008 10:52 AM
> To: Berdel, Brian
> Cc: fusion-users at lists.osgeo.org
> Subject: Re: [fusion-users] Accessing the Task Frame / Selection changed
> Hi Brian,
> You should be able to do something like this:
> Fusion.getWidgetById('TaskPane').setContent(url);
> where 'TaskPane' is the Name that is used in the ApplicationDefinition
> for defining the TaskPane widget.
> Cheers
> Paul
>> Hello all,
>> I am trying to access the task frame when a selection is made...I can
>> hook to the select widget but I really have no idea how to access
>> the task frame (Like if I wanted to perform a _postback in
>> Javascript on it or update values.)
>> Any help appreciated!
>> Thanks,
>> -Brian
>> fusion-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>     Paul Spencer
>     Chief Technology Officer
>     DM Solutions Group Inc
>     http://www.dmsolutions.ca/
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/MapServer-Fusion-Select-Tool-tp787919p1322422.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
