[fusion-users] Legend widget is not updating correctly
Paul Spencer pspencer at dmsolutions.ca
Tue Oct 14 07:49:35 EDT 2008
Rodolfo,
I don't think the legend widget will update correctly unless you call
the reloadMap method of the map widget after changing the theming of
the layer.  It is also possible (but less likely in this case) that
the browser is caching the legend images from the previous theme.
Cheers
Paul
On 13-Oct-08, at 1:55 PM, Rodolfo Moreno wrote:
> Hi all,
> Here are the steps in order to replicate the issue:
> 1. To create a new session layer (programatically)
> 2. Next, user themes the new session layer (according to his/her
> preference)
> then, the map widget is updated correctly however the legend widget is
> updated incorrectly (view the attached image).
> The attached image shows the layer reddesague(rd) themed with
> different
> color that the legend widget.
> The ranks shows in the legend widget are correct however the colors
> are
> wrongs.
> Plataform: WINDOW, IIS 6, MAPGUIDE OS 2.0.1, .NET Enviroment
> Is this issue known?
>  http://n2.nabble.com/file/n1329703/VentanillaFUSIONissue.JPG
> Rodolfo Moreno
> CivilEng
> View this message in context: http://n2.nabble.com/Legend-widget-is-not-updating-correctly-tp1329703p1329703.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://www.dmsolutions.ca/
More information about the fusion-users mailing list
