[fusion-users] Accessing the Task Frame / Selection changed
Paul Spencer pspencer at dmsolutions.ca
Tue Oct 14 07:59:07 EDT 2008
I guess its possible to request a page in an iframe using POST but I
don't know off hand how to do it.  If you can figure out how to do it,
I'll make the changes in fusion.
Cheers
Paul
On 12-Oct-08, at 10:48 AM, Rodolfo Moreno wrote:
> Hi Paul,
> It works good.
> the url obviously could has parameters using the GET method, however
> I would
> like to send the parameters with the POST method mainly for sending
> the
> selected features to my ASPX page due to that the number of selected
> features and their properties could exceed the allowable length of the
> querystring of the GET method.
> Berdel, Brian wrote:
>> Great, thanks Paul.   I'll give it a try.
>> Brian
>> -----Original Message-----
>> From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
>> Sent: Wednesday, October 08, 2008 10:52 AM
>> To: Berdel, Brian
>> Cc: fusion-users at lists.osgeo.org
>> Subject: Re: [fusion-users] Accessing the Task Frame / Selection
>> changed
>> Hi Brian,
>> You should be able to do something like this:
>> Fusion.getWidgetById('TaskPane').setContent(url);
>> where 'TaskPane' is the Name that is used in the
>> ApplicationDefinition
>> for defining the TaskPane widget.
>> Cheers
>> Paul
>>> Hello all,
>>> I am trying to access the task frame when a selection is made...I
>>> can
>>> hook to the select widget but I really have no idea how to access
>>> the task frame (Like if I wanted to perform a _postback in
>>> Javascript on it or update values.)
>>> Any help appreciated!
>>> Thanks,
>>> -Brian
>>> fusion-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>>    Paul Spencer
>>    Chief Technology Officer
>>    DM Solutions Group Inc
>>    http://www.dmsolutions.ca/
> Rodolfo Moreno
> CivilEng
> View this message in context: http://n2.nabble.com/MapServer-Fusion-Select-Tool-tp787919p1322422.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
    Paul Spencer
More information about the fusion-users mailing list
