[fusion-users] Legend widget is not updating correctly
Paul Spencer pspencer at dmsolutions.ca
Thu Oct 16 08:37:46 EDT 2008
Please do!
On 15-Oct-08, at 12:23 PM, Rodolfo Moreno wrote:
> Hi Paul,
> Could I put a ticket for this issue, in order to know when it will be
> solved?
> Thanks
> Paul Spencer-2 wrote:
>> Good.  I suppose we can add a random string to the URL that requests
>> legend images to make caching not happen, although this may cause
>> some
>> things to be less efficient.  We must proceed with caution.
>> Cheers
>> Paul
>> On 14-Oct-08, at 11:15 AM, Rodolfo Moreno wrote:
>>> Hi Paul,
>>> I am using reloadMap because is the unique way for update the legend
>>> programatically.
>>> What it happening is the second, the browser is caching the legend
>>> images
>>> from previos theme. I have cheked it and after of deleting the cache
>>> FUSION
>>> is painting correctly the legend widget either in IE and FF.
>>> Maybe it to be an issue since the map widget doesn't have this
>>> problem with
>>> the cache.
>>> Regards,
>>>> Rodolfo,
>>>> I don't think the legend widget will update correctly unless you
>>>> call
>>>> the reloadMap method of the map widget after changing the theming
>>>> of
>>>> the layer.  It is also possible (but less likely in this case) that
>>>> the browser is caching the legend images from the previous theme.
>>>> Cheers
>>>> Paul
>>>> On 13-Oct-08, at 1:55 PM, Rodolfo Moreno wrote:
>>>>> Hi all,
>>>>> Here are the steps in order to replicate the issue:
>>>>> 1. To create a new session layer (programatically)
>>>>> 2. Next, user themes the new session layer (according to his/her
>>>>> preference)
>>>>> then, the map widget is updated correctly however the legend
>>>>> widget is
>>>>> updated incorrectly (view the attached image).
>>>>> The attached image shows the layer reddesague(rd) themed with
>>>>> different
>>>>> color that the legend widget.
>>>>> The ranks shows in the legend widget are correct however the
>>>>> colors
>>>>> are
>>>>> wrongs.
>>>>> Plataform: WINDOW, IIS 6, MAPGUIDE OS 2.0.1, .NET Enviroment
>>>>> Is this issue known?
>>>>> http://n2.nabble.com/file/n1329703/VentanillaFUSIONissue.JPG
>>>>> Rodolfo Moreno
>>>>> CivilEng
>>>>> View this message in context:
>>>>> http://n2.nabble.com/Legend-widget-is-not-updating-correctly-tp1329703p1329703.html
>>>>> Sent from the Fusion Users mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> fusion-users mailing list
>>>>> fusion-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>>>>   Paul Spencer
>>>>   Chief Technology Officer
>>>>   DM Solutions Group Inc
>>>>   http://www.dmsolutions.ca/
>>> Rodolfo Moreno
>>> CivilEng
>>> http://n2.nabble.com/Legend-widget-is-not-updating-correctly-tp1329703p1332983.html
>>    Paul Spencer
> Rodolfo Moreno
> CivilEng
> View this message in context: http://n2.nabble.com/Legend-widget-is-not-updating-correctly-tp1329703p1337504.html
    Paul Spencer
    http://research.dmsolutions.ca/
More information about the fusion-users mailing list
