[fusion-users] Accessing the Task Frame / Selection changed
Rodolfo Moreno rmoreno at voxiva.com
Thu Oct 16 16:46:32 EDT 2008
Hi Paul S. and D.
Paul Spencer: Sending parameters to iframe by POST method
Give to the IFRAME a unique id/name and then set the "target" of the FORM as
that unique id/name.
sample:
<form action="page.aspx" method="post" target="myIframe">
<iframe name="myIframe" src="page.aspx"></iframe>
I hope that it to be what you want.
Paul D. the setContentURL functions doesn't exist, at least in the
taspane.js of 1.0.6 fusion version.
Cheers.
Paul Deschamps wrote:
> Hi All,
> Are we not talking about the setContentURL func? instead of the setContent
> func?
> The setContentURL triggers an Ajax call to fetch the content. We could
> change the setContentURL function to take in the Ajax "options" object as
> well as the URL so you can change it from get to post.
> Or am I totally off my rocker ;) possibly it was a long weekend ;)
> Cheers
> Paul D.
> On Tue, Oct 14, 2008 at 7:59 AM, Paul Spencer
> <pspencer at dmsolutions.ca>wrote:
>> I guess its possible to request a page in an iframe using POST but I
>> don't
>> know off hand how to do it.  If you can figure out how to do it, I'll
>> make
>> the changes in fusion.
>> Cheers
>> Paul
>> On 12-Oct-08, at 10:48 AM, Rodolfo Moreno wrote:
>>> Hi Paul,
>>> It works good.
>>> the url obviously could has parameters using the GET method, however I
>>> would
>>> like to send the parameters with the POST method mainly for sending the
>>> selected features to my ASPX page due to that the number of selected
>>> features and their properties could exceed the allowable length of the
>>> querystring of the GET method.
>>> Berdel, Brian wrote:
>>>> Great, thanks Paul.   I'll give it a try.
>>>> Brian
>>>> -----Original Message-----
>>>> From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
>>>> Sent: Wednesday, October 08, 2008 10:52 AM
>>>> To: Berdel, Brian
>>>> Cc: fusion-users at lists.osgeo.org
>>>> Subject: Re: [fusion-users] Accessing the Task Frame / Selection
>>>> changed
>>>> Hi Brian,
>>>> You should be able to do something like this:
>>>> Fusion.getWidgetById('TaskPane').setContent(url);
>>>> where 'TaskPane' is the Name that is used in the ApplicationDefinition
>>>> for defining the TaskPane widget.
>>>> Cheers
>>>> Paul
>>>>  Hello all,
>>>>> I am trying to access the task frame when a selection is made...I can
>>>>  hook to the select widget but I really have no idea how to access
>>>>> the task frame (Like if I wanted to perform a _postback in
>>>>> Javascript on it or update values.)
>>>>> Any help appreciated!
>>>>> Thanks,
>>>>> -Brian
>>>>> _______________________________________________
>>>>> fusion-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>>>>   Paul Spencer
>>>>   Chief Technology Officer
>>>>   DM Solutions Group Inc
>>>>   http://www.dmsolutions.ca/
>>> Rodolfo Moreno
>>> CivilEng
>>> View this message in context:
>>> http://n2.nabble.com/MapServer-Fusion-Select-Tool-tp787919p1322422.html
>>> Sent from the Fusion Users mailing list archive at Nabble.com.
>>   Paul Spencer
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/MapServer-Fusion-Select-Tool-tp787919p1342611.html
More information about the fusion-users mailing list
