[fusion-users] Demo works in HostLinux but not Ubuntu 8.04 Server
    Paul Deschamps
    pdeschamps at dmsolutions.ca
    Tue Oct 28 10:54:35 EDT 2008
Your problem is right there in your config.
      /* A directory on this system that fusion can use for
         temporary files. */
      "temporaryDirectory": "/tmp"
should be:
      "temporaryDirectory": "/etc/apache2/tmp"
also look at the image path and imageURL values.
      "imagePath": "/tmp/ms_tmp",
      /* The URL to the image path configured above. */
      "imageUrl": "http://localhost/tmp/ms_tmp",
      /* The file system path to where mapserver should put
          web-accessible temporary legend images. */
      "legendIconCacheDir":"/tmp/ms_
> tmp"
Cheers
Paul D
On Tue, Oct 28, 2008 at 9:51 AM, Andrew Parker <andrew at source3.com> wrote:
> I got the Fusion Demo working as discussed in
> http://n2.nabble.com/Mapfile-not-displaying-in-Fusion-for-MapServer-td1379147.html.
>  The working Demo uses HostLinux offered by HostGIS.
> When I try to view the Demo using Ubuntu 8.04 server (and Ubuntu 7.10) I
> can only see the html layout, no layer tree or toolbars.  However, I can see
> the mapfile using
> http://localhost/cgi-bin/mapserv?mode=map&map=/var/www/chp2/hello.map.
> I think the problem is where Fusion and MapServer is storing the temporary
> files.  So I started playing around with the paths.  The config.json file is
> as follows:
> /* This is the fusion configuration file.  Adjust as necessary. */
>   /* The general section contains settings that are general to
>      fusion as a whole. */
>   "general": {
>       /* PHP is the default and only script language supported.
>          Don"t change this. */
>       "scriptLanguage": "php",
>          temporary files. */
>   /* The MapGuide section is required if you are installing
>      fusion for MapGuide. */
>   "mapguide": {
>       /* The WebTierURL is the url to mapguide, it should start
>          with http and end with /mapguide.  If you have installed
>          fusion inside the www directory of MapGuide, then you can
>          leave this empty as it will be automatically calculated. */
>          "webTierUrl": ""
>   /* The MapServer section is required if you are installing fusion
>      for MapServer. */
>  "mapserver": {
>       /* The URL of the mapserver CGI that you want to use.  */
>       "cgi": "/cgi-bin/mapserv",
>           web-accessible temporary images. */
>       "legendIconCacheDir":"/tmp/ms_tmp"
> The ServerRoot in apache2 is /etc/apache2.  The apache2 DocumentRoot is
> /var/www.
> Therefore, I created the directory tmp (/etc/apache2/tmp) and set
> permission to 777.  Restarted apache2 and tested the demo.  Same results.
>  Looked in /etc/apache2/tmp and did not see any Fusion session files.  I
> also create the /tmp/ms_tmp directories in /var/www and /var.  No temp files
> were saved in these directories.
> Then I decided to change the SeverRoot to /var and /var/www to see what
> happens.  Restarted apache2 and same results, only the html layout.
> Know I am out of ideas.  Does anyone have an idea how to fix this.  I
> really want to include how to get Fusion working in Ubuntu in my HowTo I am
> writing for grad school.
> Thank you very much.
> Andrew
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
   Paul Deschamps
   Applications Specialist
   DM Solutions Group Inc.
   Office: (613) 565-5056 x28
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20081028/0dc6ca08/attachment.html
More information about the fusion-users
