[fusion-users] Demo works in HostLinux but not Ubuntu 8.04 Server
Andrew Parker andrew at source3.com
Wed Oct 29 11:33:46 EDT 2008
I will make available in a few weeks.  I need to get a demo working
using the HostGIS server first.
~andrew
Paul Deschamps wrote:
> If you make it  available on the web it would be the simplest. to
> resolve.
> On Tue, Oct 28, 2008 at 3:10 PM, Andrew Parker <andrew at source3.com
> <mailto:andrew at source3.com>> wrote:
>     Paul D:
>     I put a test image in both /var/www/tmp and /var/www/ms_tmp.  Saw
>     them both when browsed to via Firefox.  Furthermore, I see no
>     error message.  I attached a screenshot.
>     If I need too, I can make my fusion demo visible on the internet.
>      Just let me know if this will help.
>     ~andrew
>         If you put an image in /etc/apache2/tmp/ms_tmp/
>         and your browse to http://localhost/tmp/ms_tmp do you see the
>         image in the web browser.
>         Also you have not told us what error message you are receiving
>         when you browse to the fusion application.
>         Cheers
>         Paul D
>         On Tue, Oct 28, 2008 at 12:17 PM, Andrew Parker
>         <andrew at source3.com <mailto:andrew at source3.com>
>         <mailto:andrew at source3.com <mailto:andrew at source3.com>>> wrote:
>            Ok, I must be missing the obvious as I still cannot see the
>         demo.
>             I made the changes per Paul D's suggestions (see below).
>            This is what I did:
>            1. verified that the ServerRoot is "/etc/apache2"
>            2. verified that the DocumentRoot is set to "/var/www"
>            3. verified that "/etc/ apache2/tmp" exists and permissions
>         set to 777
>            4. verfied that "/var/www/tmp/ms_tmp" exists and
>         permissions set
>            to 777
>            5. Modified Fusions' config.json as shown below
>            5. Restarted apache2
>            current configuration of config.json:
>            /* This is the fusion configuration file.  Adjust as
>         necessary. */
>              /* The general section contains settings that are general to
>                 fusion as a whole. */
>              "general": {
>                  /* PHP is the default and only script language supported.
>                     Don"t change this. */
>                  "scriptLanguage": "php",
>                  /* A directory on this system that fusion can use for
>                     temporary files. */
>                  "temporaryDirectory": "/etc/apache2/tmp"
>              /* The MapGuide section is required if you are installing
>                 fusion for MapGuide. */
>              "mapguide": {
>                  /* The WebTierURL is the url to mapguide, it should start
>                     with http and end with /mapguide.  If you have
>         installed
>                     fusion inside the www directory of MapGuide, then
>         you can
>                     leave this empty as it will be automatically
>         calculated. */
>                     "webTierUrl": ""
>              /* The MapServer section is required if you are
>         installing fusion
>                 for MapServer. */
>             "mapserver": {
>                  /* The URL of the mapserver CGI that you want to use.  */
>                  "cgi": "/cgi-bin/mapserv",
>                  /* The file system path to where mapserver should put
>                      web-accessible temporary images. */
>                  "imagePath": "/var/www/tmp/ms_tmp",
>                  /* The URL to the image path configured above. */
>                  "imageUrl": "http://localhost/tmp/ms_tmp",
>                      web-accessible temporary legend images. */
>                  "legendIconCacheDir":"/var/www/tmp/ms_tmp"
>            Any other setting/configurations I should check?
>            In a twisted sort of way, I love this debugging stuff!
>            ~andrew
>                Your problem is right there in your config.
>                        temporary files. */
>                     "temporaryDirectory": "/tmp"
>                should be:
>                also look at the image path and imageURL values.
>                     "imagePath": "/tmp/ms_tmp",
>                     "legendIconCacheDir":"/tmp/ms_
>                   tmp"
>                Cheers
>                Paul D
>                On Tue, Oct 28, 2008 at 9:51 AM, Andrew Parker
>         <mailto:andrew at source3.com <mailto:andrew at source3.com>>>> wrote:
>                   I got the Fusion Demo working as discussed in
>         http://n2.nabble.com/Mapfile-not-displaying-in-Fusion-for-MapServer-td1379147.html.
>                    The working Demo uses HostLinux offered by HostGIS.
>                   When I try to view the Demo using Ubuntu 8.04 server
>         (and
>                Ubuntu
>                   7.10) I can only see the html layout, no layer tree or
>                toolbars.
>                    However, I can see the mapfile using
>         http://localhost/cgi-bin/mapserv?mode=map&map=/var/www/chp2/hello.map
>         <http://localhost/cgi-bin/mapserv?mode=map&map=/var/www/chp2/hello.map>
>         <http://localhost/cgi-bin/mapserv?mode=map&map=/var/www/chp2/hello.map>>
>         <http://localhost/cgi-bin/mapserv?mode=map&map=/var/www/chp2/hello.map>>>.
>                   I think the problem is where Fusion and MapServer is
>                storing the
>                   temporary files.  So I started playing around with the
>                paths.  The
>                   config.json file is as follows:
>                necessary. */
>         general to
>                     "general": {
>         supported.
>         use for
>                            temporary files. */
>         installing
>                     "mapguide": {
>         should start
>                installed
>         MapGuide, then
>                you can
>                calculated. */
>                            "webTierUrl": ""
>                installing fusion
>                        for MapServer. */
>                    "mapserver": {
>         to use.  */
>         should put
>         should put
>                         "legendIconCacheDir":"/tmp/ms_tmp"
>                   The ServerRoot in apache2 is /etc/apache2.  The apache2
>                   DocumentRoot is /var/www.
>                   Therefore, I created the directory tmp
>         (/etc/apache2/tmp)
>                and set
>                   permission to 777.  Restarted apache2 and tested the
>         demo.
>                 Same
>                   results.  Looked in /etc/apache2/tmp and did not see
>         any Fusion
>                   session files.  I also create the /tmp/ms_tmp
>         directories in
>                   /var/www and /var.  No temp files were saved in these
>                directories.
>                   Then I decided to change the SeverRoot to /var and
>         /var/www
>                to see
>                   what happens.  Restarted apache2 and same results,
>         only the
>                html
>                   layout.
>                   Know I am out of ideas.  Does anyone have an idea how to
>                fix this.
>                    I really want to include how to get Fusion working in
>                Ubuntu in
>                   my HowTo I am writing for grad school.
>                   Thank you very much.
>                   --    Andrew
>                   _______________________________________________
>                   fusion-users mailing list
>                   fusion-users at lists.osgeo.org
>         <mailto:fusion-users at lists.osgeo.org>
>         <mailto:fusion-users at lists.osgeo.org>>
>         <mailto:fusion-users at lists.osgeo.org>>>
>                   http://lists.osgeo.org/mailman/listinfo/fusion-users
>                --          Paul Deschamps
>                  Applications Specialist
>                  DM Solutions Group Inc.
>                  Office: (613) 565-5056 x28
>                  pdeschamps at dmsolutions.ca
>         <mailto:pdeschamps at dmsolutions.ca>
>         <mailto:pdeschamps at dmsolutions.ca>>
>         <mailto:pdeschamps at dmsolutions.ca>>>
>                  http://www.dmsolutions.ca
>                  http://research.dmsolutions.ca
>           Paul Deschamps
>           pdeschamps at dmsolutions.ca <mailto:pdeschamps at dmsolutions.ca>
>     fusion-users at lists.osgeo.org <mailto:fusion-users at lists.osgeo.org>
>    Paul Deschamps
More information about the fusion-users mailing list
