[fusion-users] Map does not draw using a virtual host
Andrew Parker andrew at source3.com
Wed Oct 29 13:40:41 EDT 2008
Perfect!  That did the trick.
I added
Alias /fusion /var/www/htdocs/fusion
to the vhosts.conf file then changed the index.html to reference
/fusion/.... rather than ../fusion/....
Thank you so much.
Hopefully I will start updating my HowTo for Fusion for MapServer this
weekend!
~andrew
Jason Birch wrote:
> Hi Andrew,
> These apps are referencing fusion as ../fusion
> I'm guessing that you have fusion at:
> and demo at:
>   /var/www/htdocs/demo
> If you create a virtual host for demo.source3.com pointing to:
> Then you can no longer reference fusion as
>   ../fusion
> because Apache cannot reference files outside of the document root.
> To solve this I would suggest either adding a line like this to your
> virtual host for Demo:
> or creating a symlink to fusion under the demo directory:
>   cd /var/www/htdocs/demo
>   ln -s /var/www/htdocs/fusion fusion
> You may also want to modify your index.html file to reference fusion as
> /fusion/ instead of ../fusion/ which will work for both cases and be
> more accurate for the virtual host.
> Jason
> -----Original Message-----
> From: fusion-users-bounces at lists.osgeo.org
> [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Andrew Parker
> Sent: Wednesday, October 29, 2008 08:57
> To: fusion-users at lists.osgeo.org
> Subject: [fusion-users] Map does not draw using a virtual host
> I have Fusion working on my server at HostGIS.  When I access the demo
> using http://216.93.173.156/demo/ the map renders.  But when I use the
> virtual host http://demo.source3.com I get an error and the map does not
> draw.  In Firebug, I see the error but cannot figure out what is causing
> it.
> HostGIS checked the server on their side and said everything is fine.
> ***  FROM HostGIS ***
> Ah, I see in the error log a major clue:
> [Tue Oct 28 12:31:48 2008] [error] [client 67.142.161.26] File does not
> exist: /var/www/htdocs/demo/fusion, referer: http://demo.source3.com/
> [Tue Oct 28 12:31:49 2008] [error] [client 67.142.161.26] File does not
> Looks to me like you didn't fix an URL in your application: it's still
> looking for /demo/fusion or something like that. Double check your URLs
> and make sure they're all correct; the webserver is behaving properly.
> *** END HostGIS  ****
> I am having the same problem with the template from
> ../fusion/template/mapserver/standard.  When I access the template from
> http://216.93.173.156/pitrule/ the map draws.  When I access the
> template from the virtual host http://pitrule.source3.com I get an
> error.  In Firebug I can see the cause of the error.  But what is
> causing it?
> Thanks for helping me so much.  Hopefully in a week or two I will have a
> good grasp of Fusion and stop asking so many questions!
> fusion-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users mailing list
