[fusion-users] Speed of Fusion vs MapFish (OpenLayers)
Andrew Parker
andrew at source3.com
Wed Oct 29 18:39:19 EDT 2008
Interesting, this gives me a starting point to try to speed up Fusion.
~andrew.
Kenneth Skovhede, GEOGRAF A/S wrote:
> A complete guess:
> Fusion uses the default ratio 1.5, meaning that the
> image downloaded/rendered is twice the size.
> If you set the ratio to 1.0 in should cut time in half (almost).
> I don't know where to set this with Fusion.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Andrew Parker skrev:
>> I am not sure if there is a way to make Fusion render maps as fast as
>> OpenLayers. At this time, I just need a yes or no answer.
>> For example, it would be great if I could make my current Fusion
>> application (http://216.93.173.156/testing/) draw the map as fast as
>> my current OpenLayers application (http//:webgis.source3.com) and my
>> MapFish test at (http://http://216.93.173.156/MFtest/).
>> What I am using for a comparison is the Topo Map Layer with the USGS
>> wells (the data is limited to New Mexico, USA) at a scale of about
>> 1:100,000. When I zoom and pan, I like how fast OpenLayers/MapFish
>> redraws.
>> I went ahead and turned on the two layers that I am using for a
>> comparison in MapFish test and my Fusion test.
>> The topo is from TerraServer. The USGS data is in PostGIS.
>> thanks,
>> ~andrew
>> fusion-users mailing list
>> fusion-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users
