[fusion-users] Speed of Fusion vs MapFish (OpenLayers)
Mike Adair madair at dmsolutions.ca
Thu Oct 30 09:19:53 EDT 2008
Andrew,
Unrelated to the tiling issue, you can optimize the initial loading time
of Fusion by creating a singleFile build as per
http://trac.osgeo.org/fusion/wiki/ANTBuildSystem
Mike
Andrew Parker wrote:
> Paul D:
> From your post, it is my understanding that Fusion does not have the
> capability to use tiles.  Is this true?  If needed, I have a
> programmer that can dedicate his time to add tile functionality.
> I set the SingleTile tag to "true" then "false" in the MapSet (file
> ApplicationDefinition.xml) to see if there was any change on the way
> Fusion rendered the map.  I did not notice any difference.  I also
> played around with the map size in the *.map file from "800 640" to
> "200 100" to "2000 1000" to see if it made any difference (curiosity,
> what else can I say).  I did not notice any difference with respect to
> speed; I am sure Fusion is overwriting this setting.  I set the final
> size to "300 300" for no reason at all.
> At this time, I am most concerned with fast rendering of the USGS topo
> maps and the Geologic Map.  Google is not that important.  But, if
> need be, I can have the programmer start working on the
> OpenLayers.Layers.Google class; I will need a little help to point him
> in the right direction.
> ~andrew
> Paul Deschamps wrote:
>> Hi Andrew,
>> hehe yes or no answer ;)
>> What you are doing here is not a "true" comparison of the three
>> different technologies.
>> Your mapfish and your openlayers application are using tiles where
>> your fusion app is not. You see in a tiled mapwindow tiles outside of
>> the mapwindow can be cached so that they display when they are
>> dragged into position. Another consideration about tiled mapviewers
>> is the size of each tile.
>> If the size of the tile requested from the server is requested at the
>> same native size of the tile on the server then the server does not
>> need to stitch tiles together.
>> All three of these examples are using Openlayers. So from a strictly
>> fetching of the map image and presenting it on the screen the
>> performance would be identical as long as the requested image is the
>> same size across all three.
>> And lastly, Your Openlayers app is using Google's Server Farm
>> directly for it's imagery where the mapfish and fusion are
>> requesting it.  so it's an extra step for every map draw.
>> Fusion is a toolkit that provides common set of map "widgets" and UI
>> controls that enable rapid application development (RAD) there's a
>> buzz wo from the past. :)
>> If you really want fusion to preform in the same fashion that your
>> openlayers app is. You can:
>> Add the OpenLayers.Layers.Google class to your openlayers.js and get
>> fusion to work with it. ( may or may not be an easy task)
>> Or wait for it to be added eventually ;)
>> Cheers
>> Paul D.
>> On Wed, Oct 29, 2008 at 5:47 PM, Andrew Parker <andrew at source3.com
>> <mailto:andrew at source3.com>> wrote:
>>     I am not sure if there is a way to make Fusion render maps as fast
>>     as OpenLayers.  At this time, I just need a yes or no answer.
>>     For example, it would be great if I could make my current Fusion
>>     application (http://216.93.173.156/testing/) draw the map as fast
>>     as my current OpenLayers application (http//:webgis.source3.com
>>     <http://webgis.source3.com>) and my MapFish test at
>>     (http://http://216.93.173.156/MFtest/).
>>     What I am using for a comparison is the Topo Map Layer with the
>>     USGS wells (the data is limited to New Mexico, USA) at a scale of
>>     about 1:100,000.  When I zoom and pan, I like how fast
>>     OpenLayers/MapFish redraws.
>>     I went ahead and turned on the two layers that I am using for a
>>     comparison in MapFish test and my Fusion test.
>>     The topo is from TerraServer.  The USGS data is in PostGIS.
>>     thanks,
>>     ~andrew
>>     _______________________________________________
>>     fusion-users mailing list
>>     fusion-users at lists.osgeo.org <mailto:fusion-users at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/fusion-users
>>    Paul Deschamps
>>    Applications Specialist
>>    DM Solutions Group Inc.
>>    Office: (613) 565-5056 x28
>>    pdeschamps at dmsolutions.ca <mailto:pdeschamps at dmsolutions.ca>
>>    http://www.dmsolutions.ca
>>    http://research.dmsolutions.ca
   Michael Adair
   Senior Software Architect
   Office: (613) 565-5056 x26
More information about the fusion-users mailing list
