[fusion-users] Error selecting features on a layer using SHP with join
Rodolfo Moreno rmoreno at voxiva.com
Thu Oct 30 19:29:16 EDT 2008
A layer using SHP WITH JOIN is displayed correctly and I can select almost
all its features except the feature that has as featId=1 (I have tested in
IE7 and FF2 obtain the same result).
SHP WITH JOIN: It's a shp(data source) which has a join to a database in
order to add properties from the database.
I have created a ticket for MGOS project for an error related "Error theming
layer using data source with joins"
(http://trac.osgeo.org/mapguide/ticket/745)
In this ticket there are two files (database access and mgp file for MGOS)
that allow replicate this error.
I have tested for manage and unmanage data source, just as SHP, SDF, and
SQL2008 providers as well.
plataform: w2003 sp2, IIS 6, MGOS 2.0.1, FUSION 1.0.6 and .NET enviroment
Is it issue known?
Cheers,
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/Error-selecting-features-on-a-layer-using-SHP-with-join-tp1400932p1400932.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
