[fusion-users] PanQuery and pink backgrounds
Paul Spencer pspencer at dmsolutions.ca
Thu Sep 11 08:13:15 EDT 2008
Hi Marc,
I haven't tried the panquery widget in a while.  The intention of the
widget was to have a dual mode widget that if you click and drag, it
pans and if you just click it does a query.  Looking at the code, it
doesn't appear to have anything that would cause it to make two
buttons.  Perhaps you have something unintentional in your
ApplicationDefinition (widget declared twice perhaps?).
As mentioned in another reply, you can set
OpenLayers.IMAGE_RELOAD_ATTEMPTS to some number greater than 1 - you
need to do that after OpenLayers code has been loaded, the best place
would probably be in the fusion initialized event handler
window.onload = function() {
   Fusion.registerForEvent(Fusion.Event.FUSION_INITIALIZED,
fusionInitialized);
   Fusion.initialize();
function fusionInitialized() {
   OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
Cheers
Paul
On 10-Sep-08, at 6:28 PM, Marc Pfister wrote:
> Two questions:
> 1.       Does the PanQuery widget work for anyone? When I add it to
> applicationdefinition.xml, it shows up as two buttons in the
> toolbar, both with the same “hand” icon. The first on is greyed out,
> the second isn’t but can’t be selected.
> 2.       Has anyone run into a case where some image in the
> OpenLayers stack fails to load and instead returns a pink background
> and the broken image icon at top left? We can occasionally make it
> happen with some aggressive mousewheel work. The fun part is that
> the pink remains as a background for all successive pans and zooms.
> I know OpenLayers is making the pink tile and I can certainly just
> have it use white once the site is in production, but I’m not really
> sure why it persists after pan and zoom redraws.
> n
> Marc Pfister
> Geospatial Data Manager
> ENPLAN
> mpfister at enplan.com
> 530/221-0440 x108
> 530/221-6963 Fax
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://www.dmsolutions.ca/
More information about the fusion-users mailing list
