[fusion-users] PanQuery and pink backgrounds
Marc Pfister mpfister at enplan.com
Mon Sep 15 13:43:05 EDT 2008
Paul,
I made the two changes and PanQuery still shows the same behavior with
two useless hand icons in the toolbar.
http://209.20.81.81/fusion/templates/mapserver/panquery/
http://209.20.81.81/fusion/templates/mapserver/panquery/ApplicationDefin
ition.xml
I do get the following error in Firebug:
oWidget is null:
  if (oWidget.isMutEx()) {
Map.js (line 812)
Marc
From: pdescham49 at gmail.com [mailto:pdescham49 at gmail.com] On Behalf Of
Paul Deschamps
Sent: Friday, September 12, 2008 8:13 PM
To: Marc Pfister
Cc: fusion-users
Subject: Re: [fusion-users] PanQuery and pink backgrounds
Hi Marc,
First in your fusion init function replace your activate widget code to
this:
   var panWidget = Fusion.getWidgetById('PanTool');
   mapWidget.activateWidget(panWidget);
Second use the pan widget definition i have provided in my earlier email
(show below) as well.
  <Widget>
        <Name>PanTool</Name>
        <Type>PanQuery</Type>
        <Description>Click or click and drag to select
features</Description>
      <Extension>
            <SelectionType>INTERSECTS</SelectionType>
            <Tolerance>25</Tolerance>
            <QueryActiveLayer>false</QueryActiveLayer>
      </Extension>
      <ImageUrl>images/icons/pan.png</ImageUrl>
      <Tooltip>Click or click and drag to select features</Tooltip>
    </Widget>
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20080915/407aeb45/attachment.html
More information about the fusion-users mailing list
