[fusion-users] Calling ZoomToSelection
Paul Deschamps pdeschamps at dmsolutions.ca
Sat Sep 27 00:26:43 EDT 2008
opps forgot to add this to the list :)
You just need to create a couple of functions and a event register for the
selection:
function onInitialize() {
    var map = Fusion.getMapById('mapwindow');
    map.registerForEvent(Fusion.Event.MAP_SELECTION_ON, selectionOn);
// event watcher.
function selectionOn() {
    var mapWidget = Fusion.getMapById('mapwindow');
    var maps = mapWidget.getAllMaps();
    var map = maps[0];
    // get the selection and trigger selectionLoaded with the obj
    map.getSelection(selectionLoaded.bind(null));
// selection loaded now zoom to the extents
function selectionLoaded(obj){
    var a = [];
    a[0] = parseFloat(obj.fMinX);
    a[1] = parseFloat(obj.fMinY);
    a[2] = parseFloat(obj.fMaxX);
    a[3] = parseFloat(obj.fMaxY);
    var map = maps[0];
    map.mapWidget.setExtents(new OpenLayers.Bounds(a[0], a[1], a[2],  a[3]));
You will notice that in the selectionLoaded Func this object will return the
extents of the selection, Now in this function you need to just trigger a
"zoomToExtents" function with the extents
Hope this helps
Cheers
Paul D.
On Fri, Sep 26, 2008 at 6:49 PM, Marc Pfister <mpfister at enplan.com> wrote:
>  So how do I execute one widget from another one? I want the MapServer
> search widget to zoom to the selection by calling the ZoomToSelection
> widget. Is there a way to trigger a widget in Fusion similar to activating
> one with activateWidget? Otherwise, what is the appropriate  JS syntax?
> Fusion.Widget.ZoomToSelection.prototype.execute() at least gets me to the
> ZoomToSelection function, but then I get an error about this.GetMap() so I
> must be blowing it in the function scope.
> n
> Marc Pfister
> Geospatial Data Manager
> ENPLAN
> 530/221-0440 x108
> 530/221-6963 Fax
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20080927/43745c93/attachment.html
More information about the fusion-users mailing list
