SV: [fusion-users] problem with localization of fusion, i think i found a bug...
Mike Adair madair at dmsolutions.ca
Fri Apr 17 10:20:02 EDT 2009
Yes it looks like Fusion is stripping off the regional part of the
locale around line 1075 of fusion.js.  Can you enter a ticket for this
please on the Fusion trac system please? http://trac.osgeo.org/fusion/
Mike
Måns Beckman wrote:
> Ok, so here is the problem. We are always sending two letter lang codes to Open Layers, that works great for some languages, but not others. For example to recognize Swedish open layers wants the code sv-SE. We will need to fix this in some way.
> Cheers
> Måns
> -----Ursprungligt meddelande-----
> Från: fusion-users-bounces at lists.osgeo.org [mailto:fusion-users-bounces at lists.osgeo.org] För Måns Beckman
> Skickat: den 17 april 2009 12:07
> Till: fusion-users at lists.osgeo.org
> Ämne: [fusion-users] problem with localization of fusion,i think i found a bug...
> Hi,
> Ok, I'm still no coder, but I found something that isn't working as it should. I was trying to localize fusion in MGE2010 and it wouldn't read my localization, so I did some code digging and found something strange.
> In this snippet from fusion.js something isn't working as it should.
>         initializeLocale: function(locale) {
>           OpenLayers.Lang.setCode(locale ? locale : window._FusionLocale);
>           this.locale = OpenLayers.Lang.code;
> To see what's happening in a simple way I modified it like this.
> alert(window._FusionLocale);
> alert(locale?locale:window._FusionLocale)
> OpenLayers.Lang.setCode(locale?locale:window._FusionLocale);this.locale=OpenLayers.Lang.code;
> alert(OpenLayers.Lang.code)
> And the result I got was in my case where I'm using a Swedish browser "sv", so window._FusionLocale is correct, "sv", so locale?locale:window._FusionLocale is reporting what I want, but then I get "en", so by some reason OpenLayers.Lang.code is reporting "en".
> Anyone who can explain why, and what I need to do to get it to work? (I can think of some quick and dirty ways to fix it, but clean code is nicer.)
> Cheers
> Måns
> fusion-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-users
> No virus found in this incoming message.
> Checked by AVG - www.avg.com
> Version: 8.5.287 / Virus Database: 270.11.58/2061 - Release Date: 04/16/09 16:38:00
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
More information about the fusion-users mailing list
