[fusion-users] loadingObj is undefined, map.query in Fusion2
Simon Pelicon simon at sl-king.com
Tue Apr 21 03:46:30 EDT 2009
Hi!
1.
I am trying to use Fusion with Mapguide 2.0.2.
I have created a new Jx.Panel and then i use setContentURL function to
some url addres.
This works fine in Fusion 1.1 but with Fusion 2.0 beta i get error:
this.loadingObj
is undefined in function
setBusy : function(isBusy) {
this.busyCount += isBusy?1:-1;
this.loadingObj.img.style.visibility =
(this.busyCount>0)?'visible':'hidden';
2.
Using map.query in Fusion 1.1 does not require geometry parameter as
Fusion 2.0. (i use Mapguide Open Source 2.0.2)
Using map.query with Fusion 2.0 without options.geometry returns error:
Invalid argument(s):
    [1] = ""
The AGF text is invalid because it failed to parse into a valid geometry
object.</h2>
    [1] = ""
object.
Exception occurred in method MgParseAwkt.ParseAwkt at line 89 in file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\geometry\Parse/ParseAwkt.cpp
If i add geometry to other parameters works ok.
options.geometry = 'POLYGON((6129642 4676854,6776931 4676854,6776931
5042345,6129642 5042345,6129642 4676854))';
options.filter = 'KAPACITET <= 100';
options.layers = 'Bakarnikabal';
options.maxFeatures = 10;
map.query(options);
How should i use query function in Fusion 2.0?
Simon
More information about the fusion-users mailing list
