[fusion-users] Maptip Error before first map image is loaded
Benoit Begin bbegin at geomapgis.ca
Wed Apr 22 11:18:33 EDT 2009
Open up the MapTip.js file inside of www\fusion\widgets\ and modify the
function named: showMaptip: function(r).
the line: if (map == null) should be if (map == null || map.isBusy())
This will prevent this error from happening. You pretty much have to modify
the code to fix the bug, but at least it works! I don't know if this also
works if Fusion is used on top of MapServer. It was just a quick hack I made
so this error didn't occur in my own projects.
Anders Selberg wrote:
> Hi all!
> I'm dabbling with a couple of applications running on MGOS 2.0.2 and
> Fusion 1.1.1 and have come across a problem with the maptip. Or, at least
> maptip is what I suspect. Here's what happens:
> If (and only if) I keep the mouse pointer in the map while the application
> is loading, I get a fusion error message like this:
View this message in context: http://n2.nabble.com/Maptip-Error-before-first-map-image-is-loaded-tp2605770p2676822.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
