[fusion-users] Commin API between Fusion and AJAX Viewer
Paul Spencer pspencer at dmsolutions.ca
Tue Apr 28 22:15:02 EDT 2009
The AJAX viewer probably seems faster and is likely more stable.
Fusion is used successfully by a number of people but the AJAX viewer
is a little simpler out of the box.  Some efforts have been made to
improve the speed of fusion, the new version to be included with MGOS
2.1 will include these updates.  You should see substantially faster
load times and general performance improvements, but I am not sure it
will be on par with the AJAX viewer yet.
Cheers
Paul
On 28-Apr-09, at 9:34 PM, Praveen Rajendra Babu wrote:
> Thanks for your time and response, Paul.
>  The only reason we are sticking to AJAX viewer is it is supposedly
> having a faster load time of maps  generally quicker and stability.
> This assessment is some months ago and not sure how things are right
> now with Fusion viewer. Do you have any opinions or thoughts about
> it at this point of time? Any benchmarks on the viewer comparison?
>  Ofcourse, I dread the idea of using frames, which is what AJAX
> viewer is made up off.
> Regards,
> Praveen
> -----Original Message-----
> From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
> Sent: Monday, 27 April 2009 10:35 PM
> To: Praveen Rajendra Babu
> Cc: fusion-users at lists.osgeo.org
> Subject: Re: [fusion-users] Commin API between Fusion and AJAX Viewer
> Its just a javascript file you can include in your fusion application
> that provides some of the global functions that the AJAX viewer
> provides. I don't think it has been documented anywhere yet, but you
> can easily open it and have a look at the functions that are provided,
> they should be self-explanatory or at least equivalent to the same
> function in the AJAX Viewer API documentation.  Not all functions have
> been duplicated though.
> Cheers
> Paul
> On 26-Apr-09, at 9:34 PM, Praveen Rajendra Babu wrote:
>> Hi,
>>     Recently I saw a post by Chris Claydon on "Mapguide Users" list
>> regarding a common API on Fusion and AJAX viewer using the
>> MapGuideViewerApi.js file.
>> Could anyone shed light on this, please?
>> Thanks for your time.
>> Regards,
>> Praveen
>> fusion-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>    Paul Spencer
>    Chief Technology Officer
>    DM Solutions Group Inc
>    http://research.dmsolutions.ca/
    Paul Spencer
More information about the fusion-users mailing list
