[fusion-users] Maptip not working
gingerbbm stuart.jones at jacobs.com
Thu Dec 3 08:14:03 EST 2009
Hi Paul
Thanks for your response. I tried this (my layer is called "TL") but to no
avail:
    <Widget xsi:type="WidgetType">
      <Name>MapTip</Name>
      <Type>Maptip</Type>
      <Extension>
        <Delay>350</Delay>
        <Maptip>
            <Label>Map Tips</Label>
            <Layer>TL</Layer>
        </Maptip>
      </Extension>
    </Widget>
The file I'm editing is C:\Program
Files\OSGeo\MapGuide\Web\www\fusion\templates\mapguide\limegold\ApplicationDefinition.xml
which I assume is the correct one. Presumably the map tip should appear
regardless of which tool is currently selected?
Stuart
View this message in context: http://n2.nabble.com/Maptip-not-working-tp3906671p4105937.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
