[fusion-users] Fusion Widget frame
Mark Pendergraft markp at Meadgilman.com
Fri Dec 11 13:31:54 EST 2009
If you want the Selection Panel to float, or show up in a different part of
the screen you can use the Jx Library to move things around, it's quite
versatile.  Why do you want the panel to be in a different frame?
-Mark P.
Twi wrote:
> Hi,
> I am currently using the Fusion MapGuide viewer.
> Does anyone know how to get out the widgets in the web-application
> (index.html)?
> I would like to use a widget outside the index. Html.
> Basically put the widget SelectionPanel in another frame.
> Is that possible?
View this message in context: http://n2.nabble.com/Fusion-Widget-frame-tp4150340p4152911.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
