[fusion-users] Fusion Widget frame
Mark Pendergraft markp at Meadgilman.com
Mon Dec 14 12:54:31 EST 2009
I don’t believe Fusion uses frames.  The JX library is how fusion pages are
laid out at runtime.  It's a UI framework, more information on it can be
found here: http://www.jxlib.org/
-Mark P.
Twi wrote:
> Twi wrote:
>> ThanK you.
>> So, I use Jx Library to move the widget in another frame ?  I use a
>> different frame
>> to receive the results of the selection. The index.html page must include
>> the map and the legend only. The widgets are placed in different frames.
>> :confused:
View this message in context: http://n2.nabble.com/Fusion-Widget-frame-tp4150340p4165718.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
