[fusion-users] Fusion, MS Access. Points cannot be selected
Shekers sh3k3rs at gmail.com
Mon Feb 16 23:07:05 EST 2009
So, I have added a Data connection in Studio to my ODBC/DSN Access file.
I've selected the geometry as the lat/long column in the table. Next, I
created a new layer with the table that has geometry. Added the layer to the
map and put that into a fusion template layout.
The points in that table display correctly.
Among the layout are shapefiles. I can select those features and display the
attributes in the Selection window without a problem. However, I am unable
to replicate this for the points from the Access file. I do not get an
error, just simply no selection (even after a refresh) and no attribute
displaying in the Selection window.
One weird thing is that I can have tooltips of these points and the
attributes do show up. Is there something wrong in my process of adding the
database?
I am using Fusion 1.1.1, FDO 3.3.2, MGOS 2.0.2 and Studio.
The points can be selected with the AjaxViewer and Attributes shows up in
the Properties panel.
Thanks
Calvin
View this message in context: http://n2.nabble.com/Fusion%2C-MS-Access.-Points-cannot-be-selected-tp2338983p2338983.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
