[fusion-users] Fusion, MS Access. Points cannot be selected
Warren Medernach wmedernach at rand.com
Tue Feb 17 00:09:48 EST 2009
Is this one of the cases where a Primary key MUST be defined for things
to work properly?
Warren M
-----Original Message-----
[mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Shekers
Sent: Monday, February 16, 2009 10:07 PM
To: fusion-users at lists.osgeo.org
Subject: [fusion-users] Fusion, MS Access. Points cannot be selected
So, I have added a Data connection in Studio to my ODBC/DSN Access file.
I've selected the geometry as the lat/long column in the table. Next, I
created a new layer with the table that has geometry. Added the layer to
the
map and put that into a fusion template layout.
The points in that table display correctly.
Among the layout are shapefiles. I can select those features and display
the
attributes in the Selection window without a problem. However, I am
unable
to replicate this for the points from the Access file. I do not get an
error, just simply no selection (even after a refresh) and no attribute
displaying in the Selection window.
One weird thing is that I can have tooltips of these points and the
attributes do show up. Is there something wrong in my process of adding
the
database?
I am using Fusion 1.1.1, FDO 3.3.2, MGOS 2.0.2 and Studio.
The points can be selected with the AjaxViewer and Attributes shows up
in
the Properties panel.
Thanks
Calvin
View this message in context:
http://n2.nabble.com/Fusion%2C-MS-Access.-Points-cannot-be-selected-tp23
38983p2338983.html
Sent from the Fusion Users mailing list archive at Nabble.com.
fusion-users mailing list
http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users mailing list
