[fusion-users] Fusion 2 is not rendering the page
Eduardo Kanegae ekanegae at gmail.com
Tue Feb 24 16:21:03 EST 2009
Thanks Paul!
It's working now.
Eduardo Kanegae
http://anthologis.com
On Tue, Feb 24, 2009 at 5:59 PM, Paul Spencer <pspencer at dmsolutions.ca> wrote:
> you need to set the correct MapId in the MapWidget tag (map_1 from looking
> at your xml).
> Hopefully that is all ...
> Paul
> On 24-Feb-09, at 3:44 PM, Eduardo Kanegae wrote:
>> hi,
>> I've successfully instaled Fusion 1.1.1 (
>> http://www.webmapit.com.br/viewmap/f1/templates/mapserver/standard/ )
>> But Fusion 2 is not rendering the page.After pointing to the address
>> http://www.webmapit.com.br/viewmap/f2/templates/mapserver/standard/
>> I can even see its page source but page is blank displayed ( IE,
>> FireFox or Chrome ).
>> My php_errors.log is showing:
>> [24-Feb-2009 17:51:39] PHP Warning:  DOMDocument::loadXML() [<a
>> href='function.DOMDocument-loadXML'>function.DOMDocument-loadXML</a>]:
>> Specification mandate value for attribute typ in Entity, line: 1 in
>> /myserver/f2/common/php/Xml2JSON.php on line 65
>> attributes construct error in Entity, line: 1 in
>> Couldn't find end of Start Tag Extension line 1 in Entity, line: 1 in
>> Premature end of data in tag Widget line 1 in Entity, line: 1 in
>> Premature end of data in tag WidgetSet line 1 in Entity, line: 1 in
>> Premature end of data in tag ApplicationDefinition line 1 in Entity,
>> line: 1 in /myserver/f2/common/php/Xml2JSON.php on line 65
>> appDefinition is at
>> http://www.webmapit.com.br/viewmap/f2/templates/mapserver/standard/ApplicationDefinition.xml
>> Is there any additional setting before running fusion 2?
>> best regards
>> Eduardo Kanegae
>> fusion-users mailing list
>> fusion-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>   Paul Spencer
>   Chief Technology Officer
>   DM Solutions Group Inc
>   http://research.dmsolutions.ca/
More information about the fusion-users mailing list
