[fusion-users] Getting started with Fusion and MGOS
Paul Spencer pspencer at dmsolutions.ca
Mon Jan 5 10:09:09 EST 2009
Hi Praveen,
sorry I've been away for a couple of weeks and am just catching up.  I
don't think there was a reply to this email.
There are a couple of ways to get a Fusion app running, probably the
simplest is just to point your web browser at
http://localhost:8008/mapguide/fusion/samples/mapguide/slate/
This will load the slate template and a default
ApplicationDefinition.xml file (that is stored outside the mapguide
repository in the same directory as the template).
If you have Studio you can create a new Flexible Web Layout and
preview it directly from Studio.  Maestro may have support for
ApplicationDefinition.xml files and Fusion but I am not sure (I
haven't tried it in a while).
The main fusion web site is http://trac.osgeo.org/fusion
Cheers
Paul
On 22-Dec-08, at 8:28 PM, Praveen Rajendra Babu wrote:
> Hello,
>        I have downloaded and installed
> MgWebServerExtensionsSetup-2.0.2.3011.exe along with MGOS
> 2.0.2.3011. I can get the sample Sheboygan dataset working with
> the .Net and PHP AJAX viewers. Now I want to use Fusion viewer to
> see the Sheboygan dataset. Any suggestions and links where I can get
> more info. on this?
> The “fusion/docs/installation.html” is referring to index.html,
> redirect.php etc…, but could n’t find anything like that obviously.
> Also, what is the Fusion home-page for latest downloads,
> documentation etc…?  Too many questions pending!
> Thanks for your time.
> Regards,
> Praveen
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://research.dmsolutions.ca/
More information about the fusion-users mailing list
