[fusion-users] Fusion Flexible Layout Errors
Praveen Rajendra Babu prbabu at openspatial.com.au
Mon Jan 19 19:07:52 EST 2009
Infact this is one question I have on Fusion - how to find its version?!
All that I could say for sure is I am using MapGuide Open Source 2.0.2.3011 and the MgWebServerExtensions version 2.0.1.2716.
I did not install Fusion on its own, basically using the one which came in as a bundle.
If the "Tasks" tab is the same as that of the task pane, then I don't see any code in that page/frame. It is basically empty, across all flexible layouts.
  Hope the above helps. Please let me know if you need more info.
-Praveen
From: Mark Pendergraft [mailto:markp at Meadgilman.com]
Sent: Tuesday, 20 January 2009 10:52 AM
To: Praveen Rajendra Babu
Subject: RE: [fusion-users] Fusion Flexible Layout Errors
What version of Fusion and MapGuide are you using?
What page is loaded into the task pane on your flexible layout?  Do you have any code in that page?
-Mark P.
From: fusion-users-bounces at lists.osgeo.org [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Praveen Rajendra Babu
Sent: Monday, January 19, 2009 3:46 PM
To: fusion-users at lists.osgeo.org
Subject: [fusion-users] Fusion Flexible Layout Errors
Hello,
     While trying to view a map created in MapGuide Studio using any of the flexible layout returns the below message:
Fusion Error:
WARNING: Exception occurred in AJAX callback.
[object Error]
xx)
With the same map if I use the "Basic" layout along with AJAX viewer, it works fine.  Any pointers in resolving this issue?
Thanks and regards,
Praveen
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20090120/c25188a8/attachment.html
More information about the fusion-users mailing list
