[fusion-users] Fusion Flexible Layout Errors
Chris Claydon chris.claydon at autodesk.com
Wed Jan 21 10:01:51 EST 2009
I apologize if this is a silly question, but do you have the maps:
Library://Maps/Overview.MapDefinition
And
Library://Maps/ESC_ZONING.MapDefinition
In your MapGuide repository?
If so, can you create a package containing your MapGuide data, and provide the URL you're using to load the layout in a browser. That should enable someone to re-produce the problem.
Chris.
From: fusion-users-bounces at lists.osgeo.org [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Praveen Rajendra Babu
Sent: Monday, January 19, 2009 6:25 PM
To: Mark Pendergraft; fusion-users at lists.osgeo.org
Subject: RE: [fusion-users] Fusion Flexible Layout Errors
Did as suggested, getting some detailed error messages as below with Fusion 1.1.0:
When requesting a web-page, I get the below message:
Fusion Error:
WARNING: Exception occurred in AJAX callback.
SyntaxError: invalid label
xx)
When doing a browser reload of the same Fusion template, I get the below 2 alert message:
ALERT #1
Fusion Error:
Message: invalid label
Location: http://osenlighten/mapguide/fusion/MapGuide/MapGuide.js (219)
Response: ERROR: Resource was not found: Library://Maps/Overview.MapDefinition
Exception occurred in method MgResourceDefinitionManager.GetDocument at line 476 in file d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
- MgResourceServiceHandler.ProcessOperation line 80 file d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
- MgOpGetResourceContent.Execute line 120 file d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\OpGetResourceContent.cpp
- MgServerResourceService.GetResourceContent line 863 file d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ServerResourceService.cpp
- MgApplicationRepositoryManager.GetResourceContent line 378 file d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ApplicationRepositoryManager.cpp
- MgResourceDefinitionManager.GetResource line 320 file d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
- MgResourceContentManager.GetDocument line 590 file d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceContentManager.cpp
- MgResourceDefinitionManager.GetDocument line 476 file d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
ALERT #2
Fusion Error:
Response: ERROR: Resource was not found: Library://Maps/ESC_ZONING.MapDefinition
From: Mark Pendergraft [mailto:markp at Meadgilman.com]
Sent: Tuesday, 20 January 2009 11:46 AM
To: Praveen Rajendra Babu
Go here:
http://download.osgeo.org/fusion/
and download the fusion-1.1.0.zip.
rename your existing fusion directory to something like "fusion-old" and unzip the 1.1.0 version into your www folder.  Than I believe you have to copy the templates into the new fusion directory.  Let us know if you continue to get the same error after upgrading your fusion installation.
-Mark
From: Praveen Rajendra Babu [mailto:prbabu at openspatial.com.au]
Sent: Monday, January 19, 2009 4:08 PM
Infact this is one question I have on Fusion - how to find its version?!
All that I could say for sure is I am using MapGuide Open Source 2.0.2.3011 and the MgWebServerExtensions version 2.0.1.2716.
I did not install Fusion on its own, basically using the one which came in as a bundle.
If the "Tasks" tab is the same as that of the task pane, then I don't see any code in that page/frame. It is basically empty, across all flexible layouts.
  Hope the above helps. Please let me know if you need more info.
-Praveen
Sent: Tuesday, 20 January 2009 10:52 AM
What version of Fusion and MapGuide are you using?
What page is loaded into the task pane on your flexible layout?  Do you have any code in that page?
-Mark P.
Sent: Monday, January 19, 2009 3:46 PM
To: fusion-users at lists.osgeo.org
Subject: [fusion-users] Fusion Flexible Layout Errors
Hello,
     While trying to view a map created in MapGuide Studio using any of the flexible layout returns the below message:
Fusion Error:
[object Error]
xx)
With the same map if I use the "Basic" layout along with AJAX viewer, it works fine.  Any pointers in resolving this issue?
Thanks and regards,
Praveen
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20090121/e79d743d/attachment.html
More information about the fusion-users mailing list
