[fusion-users] legend.currentRange JavaScript Error?
Jason Birch Jason.Birch at nanaimo.ca
Thu Jul 23 04:18:45 EDT 2009
I saw this problem crop up on earlier versions of Fusion (like the one I'm currently running) when there are hidden folders in the legend.  I've also seen funky behaviour with themed layers at the top level of the map causing the entire legend not to load.
I'm refraining from reporting these because they may well have been fixed in the heavily modified legend code in 2.0.  Sounds like we need some kind of testing framework though... How does one do tests against JS, especially a library with a strong server-side requirement.  Sounds tough.
Jason
-----Original Message-----
Sent: Wednesday, July 22, 2009 2:29 PM
Subject: Re: [fusion-users] legend.currentRange JavaScript Error?
HI Paul, I think I found the root cause of the error.  I have been tricky
with my Layer Names .
For example rather than the Legend Label showing:
Parcel Polygons
I have:
<b>Parcel</b> Polygons
This works great with the Basic AJAX viewer but causes havoc with FUSION..
No funky legends for me!
More information about the fusion-users mailing list
