[fusion-users] compatibility problems
Mauricio Herrera georazor at gmail.com
Sat Jun 6 00:58:14 EDT 2009
> Hi Tim  thanks for answering...
> Sorry Tim,  I can't provide you my mapfile for one reason... If you want to
> test my mapfile in your MapServer... Your  MapServer doesn't detect my new
> keywords..because I modify MapServer source code for adapting my new
> keywords..
> Before I explain you that I had developed a new keywords for MapServer and
> I haven't had  problems for testing my keywords in a simple HTML
> application (mode CGI).. Only I have had problems with Fusion 1.1.1 ..It
> doesn't show  my maps.. If I delete or comment (#) my new keywords in the
> mapfile, Fusion show me the maps....
> My especific question is: Do I need to develop some PHP code  in Fusion for
> detecting my new keywords? or it is not necessary
> Note: I refer a new keywords  for example (It is only a example)
> LAYER
>      NOTE
>         BNT 5
           INFO  HOLA
>      END
> END
> 2009/6/4 Mauricio Herrera <georazor at gmail.com>
> Hello Fusion users
>> I have serious problem... Well really I have a big doubt.. I hope you can
>> help me
>> My questions are:
>> 1.- Fusion 1.1.1  is compatible with new versions of MapServer 5.4.0 or
>> possible next versions?
>> 2.-With what version of MapServer  is compatible Fusion 1.1.1? or no
>> matter?
>> 3.-What happen if the mapserver developers add new functions or keywords
>> in the mapfile? Will Fusion detect or recognize? Fusion continue to operate?
>> or for every version of mapserver ,  Fusion developer need to do
>> implementations?
>> I explain my before questions:  I develop a new keywords for MapServer in
>> the  mapfile.. and I dont have any problem for testing my keywords in a
>> simple HTML  application and mode CGI.. Only I have problems with Fusion..It
>> does not show me my maps.. If I delete or comment my new keywords in the
>> Thank you
>> Mauricio
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20090605/e95195e0/attachment.html
More information about the fusion-users mailing list
