[fusion-users] Can I make a popup layer directly over the map like Google?
Paul Deschamps pdeschamps at dmsolutions.ca
Fri Jun 12 09:51:29 EDT 2009
Here's some JavaScript that will get you started. I have quickly taken it
apart from an application i've developed. It may or may not work for you but
it will give you a good place to start.
Be sure to checkout the OpenLayers Documentation.
Cheers
Paul D.
function onInitialize - Fusion.Event Handler
function onInitialize() {
    var map = Fusion.getMapById('mapArea');
    map.registerForEvent(Fusion.Event.MAP_SELECTION_ON, selectionOn);
    map.registerForEvent(Fusion.Event.MAP_LOADED, mapIsLoaded);
function selectionOn - Selection activated
function selectionOn() {
    var mapWidget = Fusion.getMapById('mapArea');
    var maps = mapWidget.getAllMaps();
    var map = maps[0];
    // get the selection and trigger selectionLoaded with the obj
    map.getSelection(selectionLoaded.bind(null));
function selectionLoaded - Selection loaded
function selectionLoaded(obj){
    // set defaults for the cloud popup
    var AutoSizeFramedCloud = OpenLayers.Class(OpenLayers.Popup.FramedCloud,
        'autoSize': true,
        'minSize': new OpenLayers.Size(300,300),
        'fixedRelativePosition':true,
        'relativePosition':'tr'
    lonLat = new OpenLayers.LonLat(obj.fMaxX,obj.fMaxY);
    // add the marker
    addMarkerPopup(lonLat, AutoSizeFramedCloud, obj, true,true);
function addMarkerPopup - Creates the OL Feature Marker and FramedCloud
Popup
function addMarkerPopup(ll, popupClass, popupContentHTML, closeBox,
overflow) {
    d.log("addMarkerPopup");
    // get map
    // build feature
    var feature = new OpenLayers.Feature(markerLayer, ll);
    feature.closeBox = closeBox;
    feature.popupClass = popupClass;
    feature.data.popupContentHTML = popupContentHTML;
   // feature.data.overflow = (overflow) ? "auto" : "hidden";
    var size = new OpenLayers.Size(14,24);
    var offset = new OpenLayers.Pixel(-(size.w/2), -size.h);
    var appHost = Fusion.getApplicationURL();
    var icon = new
OpenLayers.Icon(appHost+'images/marker-2.png',size,offset);
    var marker = new OpenLayers.Marker(ll,icon);
    // create popup and show it.
    this.popup = feature.createPopup(feature.closeBox);
    map.oMapOL.addPopup(this.popup);
    this.popup.show();
    // add eventhandler for marker to popup
    var markerClick = function (evt) {
        if (this.popup == null) {
            this.popup = this.createPopup(this.closeBox);
            this.popup.show();
        } else {
            this.popup.toggle();
        currentPopup = this.popup;
        OpenLayers.Event.stop(evt);
    marker.events.register("mousedown", feature, markerClick);
    markerLayer.addMarker(marker);
function mapIsLoaded -  Fusion.Event Handler
function mapIsLoaded() {
    // create the markers layer
    markerLayer = new OpenLayers.Layer.Markers( "Markers" );
    // set units
    markerLayer.units = map.oMapOL.units;
    // add the marker layer to the OL Map.
    map.oMapOL.addLayer(markerLayer);
    // set the resolutions for the markers layer
    //markerLayer.maxResolution = map.oMapOL.baseLayer.maxResolution;
    //markerLayer.minResolution = map.oMapOL.baseLayer.minResolution;
    // set extents to be a bit larger then the current area.
    var map = maps[0];
    var bounds = new OpenLayers.Bounds(100000,4800000,600000,5500000);
    map._oMaxExtent = bounds
    map.oLayerOL.maxExtent = bounds
On Fri, Jun 12, 2009 at 8:32 AM, Paul Spencer <pspencer at dmsolutions.ca>wrote:
> It hasn't been done yet, but it is definitely possible to use
> OpenLayers.Popup which does a google-style popup dialog on the map.  I
> haven't tried it myself but I have seen it done.
> Paul
> On 11-Jun-09, at 9:41 PM, jroberts wrote:
>> Our developers we see no way to make the properties of a selection appear
>> directly over the map in a popup window (sort of like Google Maps). Is
>> this
>> at all possible to do?
>> We'd love to get rid of the properties panel and display selection
>> information over the map.
>> Thanks.
>> View this message in context:
>> http://n2.nabble.com/Can-I-make-a-popup-layer-directly-over-the-map-like-Google--tp3065516p3065516.html
>> Sent from the Fusion Users mailing list archive at Nabble.com.
>> fusion-users mailing list
>> fusion-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>   Paul Spencer
>   Chief Technology Officer
>   DM Solutions Group Inc
>   http://research.dmsolutions.ca/
   Paul Deschamps
   Applications Specialist
   DM Solutions Group Inc.
   Office: (613) 565-5056 x28
   http://www.dmsolutions.ca
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20090612/b7eaef45/attachment.html
More information about the fusion-users mailing list
