[fusion-users] Maptips Off When Layer Off
Paul Deschamps pdeschamps at dmsolutions.ca
Tue Jun 30 10:27:18 EDT 2009
The way map tips works is like an automatic query. if it's queryiable it
will show in the results.  You are correct it does not check min / max
scales. and preferably it should.
You should log a ticket on this issue.
Cheers
Paul D.
On Tue, Jun 30, 2009 at 9:08 AM, Nolte, Tim
<Tim.Nolte at ipcswirelessinc.com>wrote:
> I really like the Maptips feature, however the issue I have is that
> there are Maptips popping up for features that aren't even visible on
> the map. Seems like Maptips shouldn't show up unless a layer is actually
> on at the current zoom level.
> - Tim
> Timothy J Nolte - tnolte at ilpcs.com
> Network Planning Engineer
> iPCS Wireless, Inc.
> 4717 Broadmoor Ave, Suite G
> Kentwood, MI 49512
> Office: 616-656-5163
> PCS:    616-706-2438
> Fax:    616-554-6484
> Web: www.ipcswirelessinc.com
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
   Paul Deschamps
   Applications Specialist
   DM Solutions Group Inc.
   Office: (613) 565-5056 x28
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20090630/ab9a7284/attachment.html
More information about the fusion-users mailing list
