[fusion-users] MapGuide HTTP tiles with Fusion?
Jason Birch Jason.Birch at nanaimo.ca
Mon Mar 2 03:09:45 EST 2009
Hi all,
Zac's done some work getting MapGuide tiles to serve up as straight HTTP requests.  This technique, combined with multiple hosts (maptiles1.nanaimo.ca, maptiles2.nanaimo.ca, etc) would really make MapGuide tile serving smoke.
http://trac.openlayers.org/ticket/1622
Does anyone know if this method could be:
 - supported as a layer type under Fusion 2
 - added to a Fusion map as a "base layer" at the bottom of a dynamic MapGuide layer?
And, failing this, can a standard MapGuide tiled map be used as a base layer at the bottom of a dynamic MapGuide layer in a single Fusion map?
This would be a "killer feature" for me.  If it can't currently be done, what kind of effort would be involved in supporting this?
Thanks,
Jason
More information about the fusion-users mailing list
