[fusion-users] MapGuide HTTP tiles with Fusion?
Jason Birch Jason.Birch at nanaimo.ca
Mon Mar 2 10:55:06 EST 2009
Yes, I'm just not sure to what extent Fusion2 supports arbitrary layers.  I guess my questions are:
- Can multiple OL layers be combined in a single Fusion2 map?
- Can Fusion2 pass through the boolean configuration value required to use an HTTP-based MapGuide tiled map?
And if so, can I see an example of what the AppDef would look like for these?
Jason
From: Zac Spitzer [mailto:zac.spitzer at gmail.com]
Sent: Mon 2009-03-02 12:19 AM
To: Jason Birch
Cc: fusion-users at lists.osgeo.org
Subject: Re: [fusion-users] MapGuide HTTP tiles with Fusion?
fusion 2 is going to support arbitrary openlayers layers i believe :)
the pain is still the manual configuration required to set things up
More information about the fusion-users mailing list
