[fusion-users] Fusion 2 widgets not rendering properly
Paul Spencer pspencer at dmsolutions.ca
Thu Mar 12 08:55:19 EDT 2009
Wow.  Very difficult to tell what is going on from the screenshots but
I can confirm that it is definitely messed!
Is there any code/app def that you can share with us?  There were
substantial, non-backwards-compatible changes in the Jx user interface
library between 1.1 and 2.0 so if you created your own html template
with custom javascript using the Jx library, it would probably not
work any more, or at least not the way you would expect, and might
cause this kind of problem
Cheers
Paul
On 9-Mar-09, at 3:57 PM, Bill Ten Broeck wrote:
> I've attached 2 screen shots. Fusion1.jpg shows 2 toolbars and the
> legend as they should look. Fusion2.jpg is the way they look after
> installing Fusion 2.
> By looking at these, is there something obvious I am doing wrong
> with my install?
> Thanks,
> Bill
> Fusion1
> .jpg><Fusion2.jpg>_______________________________________________
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://research.dmsolutions.ca/
More information about the fusion-users mailing list
