[fusion-users] Adding two or more maps
wood77 ravinda_h at hotmail.com
Wed Mar 18 05:26:59 EDT 2009
Hi Chris, thank you for the reply.
 In Fusion 2.0 I get the MapGroup like below,
<?xml version="1.0" encoding="utf-8"?>
<MapSet xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
  <MapGroupType id="Osaka">
    <Map>
      <Type>MapGuide</Type>
      <SingleTile>true</SingleTile>
      <Extension>
<ResourceId>Library://Buildings/Osaka/Maps/MapO.MapDefinition</ResourceId>
      </Extension>
    </Map>
    <Extension />
  </MapGroupType>
  <MapGroupType id="Music">
    <Map>
      <Extension>
<ResourceId>Library://Buildings/Music/Maps/MapM.MapDefinition</ResourceId>
      </Extension>
    </Map>
    <Extension />
  </MapGroupType>
  </MapSet>
I can select the maps in map menu, but it wont load the map.I can even get
the Legend panel for the selected map, but not the map.
Thanks.
Chris Claydon wrote:
> When you edit the MapGroup XML with Fusion 2.0, what do you get in the map
> menu?
> -----Original Message-----
> From: fusion-users-bounces at lists.osgeo.org
> [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of wood77
> Sent: Tuesday, March 17, 2009 5:05 AM
> To: fusion-users at lists.osgeo.org
> Subject: [fusion-users] Adding two or more maps
> Hi All,
>  How to I add two or more maps to the Map menu. I was able to do that with
> MGOS 2.0.0 with fusion 1.1 by editing MapGroup XML. But with MGOS 2.0.2
> and
> Fusion 2.0 it wont work properly.
> Thanks.
> http://n2.nabble.com/Adding-two-or-more-maps-tp2490702p2490702.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-users
View this message in context: http://n2.nabble.com/Adding-two-or-more-maps-tp2490702p2496114.html
More information about the fusion-users mailing list
