[fusion-users] CTRLClick Widget
Mike Adair
madair at dmsolutions.ca
Thu Mar 26 09:14:10 EDT 2009
The CTRLClick widget is pretty out of date (from the 1.0 branch). I
think you would have better luck if you updated to a more current
version of Fusion (CTRLClick is implemented in the layer objects using
OpenLayers handlers which is much more robust).
However, looking at the code for Fusion 1.0, it looks like you need to
add some <Layer> elements in the Extension:
<Extension>
<Layer>Parcels</Layer>
<Layer>Roads</Layer>
</Extension>
Mike
jcabrera wrote:
> I am trying to modify the default ctrl click behavior. I registered the CTRLClick widget in my applicationdefinition.xml:
> <Widget>
> <Name>CTRLClick</Name>
> <Type>CTRLClick</Type>
> <Location />
> <Extension>
> <ElementId />
> </Extension>
> </Widget>
> I see it being created, but the _display function is not being hit. What do I need to do to get it working?
> Jorge
Michael Adair
Senior Software Architect
DM Solutions Group Inc.
Office: (613) 565-5056 x26
http://www.dmsolutions.ca
http://research.dmsolutions.ca
More information about the fusion-users
