[fusion-users] MapServer Legend Icons
Nolte, Tim Tim.Nolte at ipcswirelessinc.com
Thu Nov 5 15:03:37 EST 2009
Is this forum and/or project dead? How many people are actually using
this or developing for it?
Well, on a good note I finally got a somewhat working solution by
basically forgetting about trying to rely on $_SESSION and basically
copied a bunch of the LoadMap code that sets up the Scale Ranges over to
the LoadScaleRanges script. I also changed the script to also not rely
on the $_SESSION to tell it what mapfile it is supposed to use and
basically copied the code in LoadMap that sets up the SESSION based map.
There is still the issue of the Legend being sorted backwards, the
Legend icons not all updating properly when zooming in, as well as an
issue with the map layers not being stacked in the right order. I'm
plugging away at this. It would be really nice if no one else is really
working on MapServer specific development that I could start submitting
to the SVN or somehow my changes could get approved to be taken into the
project. I'll hate to have to use a diff utility every time there is an
update and have to fix my code so that things still work. Thanks to
anyone that is actually reading this, if there is anyone out there.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS:    616-706-2438
Fax:    616-554-6484
Web: www.ipcswirelessinc.com
-----Original Message-----
[mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Nolte, Tim
Sent: Wednesday, November 04, 2009 4:08 PM
To: Paul Spencer
Cc: fusion-users at lists.osgeo.org
Subject: RE: [fusion-users] MapServer Legend Icons
Paul,
I attempted this, however what I found was that the way the loading
process happens it is not enough to just stick the scale ranges into the
PHP $_SESSION. I'm finding that all of the individual maps in many cases
don't yet exist in the SESSION when the corresponding LoadScaleRanges is
called. Do you have any thoughts on how Fusion could be changed to only
call LoadScaleRanges 1 time after all of the LoadMap calls have
finished? I think this could be the fix. The only other option I see is
that the whole scale ranges creation process needs to be duplicated in
LoadScaleRanges script. I'm not sure but perhaps this functionality
needs to be added to the Utilities script?
iPCS Wireless, Inc.
Kentwood, MI 49512
PCS:    616-706-2438
Fax:    616-554-6484
[mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Paul Spencer
Sent: Monday, October 26, 2009 3:07 PM
To: Nolte, Tim
Subject: Re: [fusion-users] MapServer Legend Icons
Ohhhhh - light goes on - doh!  You have 6 maps in the same map group!
This will need a bit of work :)  We need to modify the scale_ranges
array in the session so that it is subdivided by map name.  LoadMap
needs to set
$_SESSION['scale_ranges'][$mapName]
and LoadScaleRanges needs to use the same thing when referencing it.
Do you think you could make these changes and test?  If it works, I'll
file the bug and commit.  If you don't want to try first, I can take a
stab at it and commit but I'm not really set up to test right now.
Thanks Tim
Paul
On 2009-10-26, at 2:39 PM, Nolte, Tim wrote:
> What I am seeing with Firebug is that there are 6 calls to
> LoadMap.php,
> which are my 5 main maps and 1 overview map. After the 5th LoadMap.php
> call then the LoadScaleRanges.php calls begin, there are 5 calls. One
> thing that I noticed also is that the MapTips are not working and what
> is being POSTed to the MapTip.php script is the wrong map for the
> layer
> that I've selected for MapTips. Seems like there could be a problem
> with
> using the SESSION if the LoadMap.php is not adding something to the
> SESSION to directly link the call to the LoadScaleRanges.php so that
> it's not pulling the wrong scale_ranges. Is there any debugging
> information that I can send?
> - Tim
> iPCS Wireless, Inc.
> Kentwood, MI 49512
> PCS:    616-706-2438
> Fax:    616-554-6484
> From: fusion-users-bounces at lists.osgeo.org
> Spencer
> Sent: Monday, October 26, 2009 11:30 AM
> To: Nolte, Tim
> Hi Tim,
> The legend icon stuff is working in another project that Paul
> Deschamps is working on, he has multiple map files and a menu for
> changing between them.  The legend does appear to update correctly
> when changing maps.
> The way it *should* work is that LoadMap.php populates a session
> variable 'scale_ranges' with an array of each scale range of each
> class of each layer.  LoadScaleRanges.php uses this array to get the
> class for each scale range and draw the icon at the appropriate scale
> for that class and then combines them all into a single image, and
> returns a set of CSS offset values for use by the legend - so each
> scale range has the same image source but different offsets.
> I suspect what is going wrong is that the scale_ranges array is
> somehow the wrong one.  We need to know what sequence is causing
> this.  Is LoadScaleRanges being called before LoadMap finishes?  Or
> are you programmatically changing maps while loading them or between
> loading and calling LoadScaleRanges?
> Cheers
> Paul
> On 2009-10-26, at 10:38 AM, Nolte, Tim wrote:
>> Last week I had posted about a problem with my legend icons not
>> showing
>> up. I have multiple MapServer mapfiles defined. I'm not sure if the
>> problem I'm having is solely related to having multiple mapfiles or
>> that
>> I recently updated to the latest Fusion trunk. I can say that the
>> problem with the legend icons is because of an error in
>> layers\MapServer\php\LoadScaleRanges.php, the section that it is
>> having
>> a problem with is:
>> 	$oImg = $oClass->createLegendIcon($nIconWidth, $nIconHeight);
>> This is failing with the error:
>> 	Fatal error: Call to a member function createLegendIcon() on a
>> non-object
>> If I change the code to make sure that '$oClass' is not NULL then
>> legend
>> icons do get created but they are not being created correctly. I'm
>> not
>> sure if this is something where I need to use a different built-in
>> function to use one of the default Fusion layer icons? If anyone has
>> any
>> ideas it would be a big help.
>> - Tim
>> iPCS Wireless, Inc.
>> Kentwood, MI 49512
>> PCS:    616-706-2438
>> Fax:    616-554-6484
>> fusion-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>    Paul Spencer
>    Chief Technology Officer
>    DM Solutions Group Inc
>    http://research.dmsolutions.ca/
    Paul Spencer
More information about the fusion-users mailing list
