[fusion-users] MapServer Legend Icons
Nolte, Tim Tim.Nolte at ipcswirelessinc.com
Mon Oct 26 10:38:30 EDT 2009
Last week I had posted about a problem with my legend icons not showing
up. I have multiple MapServer mapfiles defined. I'm not sure if the
problem I'm having is solely related to having multiple mapfiles or that
I recently updated to the latest Fusion trunk. I can say that the
problem with the legend icons is because of an error in
layers\MapServer\php\LoadScaleRanges.php, the section that it is having
a problem with is:
	$oImg = $oClass->createLegendIcon($nIconWidth, $nIconHeight);
This is failing with the error:
	Fatal error: Call to a member function createLegendIcon() on a
non-object
If I change the code to make sure that '$oClass' is not NULL then legend
icons do get created but they are not being created correctly. I'm not
sure if this is something where I need to use a different built-in
function to use one of the default Fusion layer icons? If anyone has any
ideas it would be a big help.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS:    616-706-2438
Fax:    616-554-6484
Web: www.ipcswirelessinc.com
More information about the fusion-users mailing list
