[fusion-users] MapServer Legend Icons
Nolte, Tim Tim.Nolte at ipcswirelessinc.com
Mon Oct 26 14:39:52 EDT 2009
What I am seeing with Firebug is that there are 6 calls to LoadMap.php,
which are my 5 main maps and 1 overview map. After the 5th LoadMap.php
call then the LoadScaleRanges.php calls begin, there are 5 calls. One
thing that I noticed also is that the MapTips are not working and what
is being POSTed to the MapTip.php script is the wrong map for the layer
that I've selected for MapTips. Seems like there could be a problem with
using the SESSION if the LoadMap.php is not adding something to the
SESSION to directly link the call to the LoadScaleRanges.php so that
it's not pulling the wrong scale_ranges. Is there any debugging
information that I can send?
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS:    616-706-2438
Fax:    616-554-6484
Web: www.ipcswirelessinc.com
-----Original Message-----
[mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Paul Spencer
Sent: Monday, October 26, 2009 11:30 AM
To: Nolte, Tim
Cc: fusion-users at lists.osgeo.org
Subject: Re: [fusion-users] MapServer Legend Icons
Hi Tim,
The legend icon stuff is working in another project that Paul
Deschamps is working on, he has multiple map files and a menu for
changing between them.  The legend does appear to update correctly
when changing maps.
The way it *should* work is that LoadMap.php populates a session
variable 'scale_ranges' with an array of each scale range of each
class of each layer.  LoadScaleRanges.php uses this array to get the
class for each scale range and draw the icon at the appropriate scale
for that class and then combines them all into a single image, and
returns a set of CSS offset values for use by the legend - so each
scale range has the same image source but different offsets.
I suspect what is going wrong is that the scale_ranges array is
somehow the wrong one.  We need to know what sequence is causing
this.  Is LoadScaleRanges being called before LoadMap finishes?  Or
are you programmatically changing maps while loading them or between
loading and calling LoadScaleRanges?
Cheers
Paul
On 2009-10-26, at 10:38 AM, Nolte, Tim wrote:
> Last week I had posted about a problem with my legend icons not
> showing
> up. I have multiple MapServer mapfiles defined. I'm not sure if the
> problem I'm having is solely related to having multiple mapfiles or
> that
> I recently updated to the latest Fusion trunk. I can say that the
> problem with the legend icons is because of an error in
> layers\MapServer\php\LoadScaleRanges.php, the section that it is
> having
> a problem with is:
> 	$oImg = $oClass->createLegendIcon($nIconWidth, $nIconHeight);
> This is failing with the error:
> 	Fatal error: Call to a member function createLegendIcon() on a
> non-object
> If I change the code to make sure that '$oClass' is not NULL then
> legend
> icons do get created but they are not being created correctly. I'm not
> sure if this is something where I need to use a different built-in
> function to use one of the default Fusion layer icons? If anyone has
> any
> ideas it would be a big help.
> - Tim
> iPCS Wireless, Inc.
> Kentwood, MI 49512
> PCS:    616-706-2438
> Fax:    616-554-6484
> fusion-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-users
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://research.dmsolutions.ca/
More information about the fusion-users mailing list
