[fusion-users] Re: MapServer/Fusion/Select Tool
Edi.Karadumi edikaradumi at gmail.com
Tue Aug 17 10:12:24 EDT 2010
yep i found another post that said that we should change
\ms4w\apps\fusion\MapServer\php\query.php all references from query.qry to
query.qy. Than it didnt work again, but the problem was the order of the
layers. i put the layer that i query on top of the others, and it still has
some problems. if i select some elements and then zoom in/out of the min/max
scale of that layer, than i cant see any data.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MapServer-Fusion-Select-Tool-tp2061918p5432279.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
