[fusion-users] Application definition with other services.
Paul Spencer pspencer at dmsolutions.ca
Tue Feb 2 10:52:56 EST 2010
There is no direct way to work with either at this time but you should be able to use GeoServer as a WMS layer.  Not sure about Mapnik.  In both cases, if you wanted to work directly with them (i.e. expose functionality like query, selection, layer styling etc) you would need to write a new backend for Fusion in the appropriate language (java, python) by porting the existing PHP files and methods in the MapServer/MapGuide layer types.
Cheers
Paul
On 2010-02-02, at 6:17 AM, Tómas Guðmundsson wrote:
> Hi.
> Obviously the documentation that is offered on the trac website is showing how people can use Mapserver, Google Maps or other maps as in Fusion.
> What I was wandering is if anyone has accomplished to use either GeoServer or Mapnik server in combination with Fusion and the ApplicationDefinition.
> If so the xml snippet or any help cooking up that xml snippet would be very helpful.
> Thank you,
> Tomas
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
   Paul Spencer
   Chief Technology Officer
   DM Solutions Group Inc
   http://research.dmsolutions.ca/
More information about the fusion-users mailing list
